LSX alternator relocation kit
Old Apr 22, 2012 | 07:51 PM
  #221
ModularTurbo's Avatar
Originally Posted by PRAY HRD
Looks great! But is there a price minus the belt? i have an slp crank pulley, meziere street pump, no a/c or p/s and a power master alt but i'd rather buy it and have it all set up and ready to go for when i need the belt.
thanks!
No Belt $165.00+Shipping
Old Apr 22, 2012 | 08:41 PM
  #222
theblur98ss's Avatar
Mine arrived on friday and should be installed tomorrow. Looks like a great piece so far.
Old Apr 22, 2012 | 10:28 PM
  #223
PRAY HRD's Avatar
sounds good to me! i'll be in touch as soon as i'm ready for it.
Old Apr 23, 2012 | 01:20 PM
  #224
RedRocketZ28's Avatar
I got mine in last week. It's a very nice piece.
Old May 13, 2012 | 10:34 PM
  #225
Pat-Man's Avatar
Awesome piece for sure! Installed mine this weekend. Fitment was great, very sturdy and you can adjust the belt tension by hand. Thanks guys for such a great product!
Out with the old system that I could never get the belt to fit right:
In with the new!
Old May 18, 2012 | 03:24 PM
  #226
cajunss's Avatar
With this kit do you have to re wire are just re route the wires to the new location?
Old May 18, 2012 | 06:53 PM
  #227
re-route works just fine
Old May 25, 2012 | 02:27 PM
  #228
ls1fan00's Avatar
i am thinking about buying one of these as mine is not working with my 145amp alt. on your website, you say 145 AMP LS1 truck alternator. Note: valve cover oil filler tube will need to be modified.
can you explain a little more before i order?
Old May 25, 2012 | 10:09 PM
  #229
Look on page 4 of this thread post#76.
A guy is using a 145 AMP alternator.
Here is the link.
https://ls1tech.com/forums/forced-in...ion-kit-4.html
Old May 29, 2012 | 12:00 PM
  #230
cajunss's Avatar
Few more questions:
1:Will this clear a SS hood?
2:I will be running a 10% ATI pulley how can I find out what size belt I need?
3: How do you set the belt if this is replacing the belt tensioner?
Thanks sorry for all the questions.
Old May 29, 2012 | 12:32 PM
  #231
Here is a link to Josh Forster's 200 + MPH Camaro with a flat hood, it clears.
http://www.lsxtv.com/features/car-fe...e-mile-at-cms/
Here is a link with pic's that show the rod end adjusting system that tightens the belt.
Order it without the belt if you have a under drive pulley.
We leave the belt choice up to the customer when they are running aftermarket under drive pulley's.
There are so many under drive systems out there it is hard for us to keep a belt in stock for everyone.
Old May 29, 2012 | 12:38 PM
  #232
KILLER-LS1's Avatar
Modular Turbo:
Hey, I have your alt bracket and love it, however I made a big improvement on it that I think you guys could add to the product.
I added an idler pulley to the bottom bolt hole on the bracket. I used the pulley from the old stock alt bracket, and the spacing worked out so there is no interference with the other bolt head. the reason I did this was because there was too much belt unsupported, and on the dyno, and long pulls, the belt would shake around and touch my thermostat housing. Not a big deal but I just wanted to tighten it up a bit.
For the spacer for the idler, I cut off the tab on the factory bracket where the idler normally bolts to. I then ground down the back of that piece to make it flat. After measuring a few times, I just cut the back of the tab until the pulley lined up with the belt, and still had good clearance between the other bolt head.
If you guys want, I can take a couple pics.
Old May 29, 2012 | 12:41 PM
  #233
KILLER-LS1's Avatar
http://www.lsxtv.com/features/josh-f...he-mojave-mile
^^^ Oh hey! Thats me!
Yeah the reason I made the idler was because of those mile long runs. Its really a lot of stress on that serpentine belt. I've got to say though, I love the bracket! Saved me a lot of headache.
Old May 29, 2012 | 01:41 PM
  #234
Your right, there is a lot of real estate between the crank pulley and alternator.
Post some pic's of that mod you made.
Anything to make it better!
Old Jun 3, 2012 | 03:51 PM
  #235
PRAY HRD's Avatar
getting very close to that time for me and would love to see something with an idler pulley Killer! it's time to show it off!
Old Jun 3, 2012 | 08:11 PM
  #236
KILLER-LS1's Avatar
I would, but I've been out of town for a while, and don't get home until this friday. I'll get some pics over the weekend!
Old Jun 4, 2012 | 02:39 PM
  #237
laytoncamaroz28's Avatar
Just ordered mine
Old Jul 31, 2012 | 11:24 AM
  #238
jdmv8's Avatar
Anyone have any ideas for how to get this bracket to work with a CTS-V crank pulley and waterpump? Mine keeps throwing the belt on start up. Everything worked perfect before I switched to a smaller crank pulley to make room for a bigger sway bar.
Old Aug 2, 2012 | 08:48 AM
  #239
cajunss's Avatar
anyone running this with an ATI 10% pulley? If so what belt you are using?
Old Aug 3, 2012 | 11:54 AM
  #240
Freeman83's Avatar
Looks like ill be purchasing one of these brackets for my s10. my engie didnt come with the idler pulley on the drivers side, do you offer that as well?
