LSX alternator relocation kit
Old Oct 2, 2011 | 08:28 PM
  #201
chevymec's Avatar
Originally Posted by cookba
is anyone using this kit with a Meziere EWP and Katech belt tensioner? I am not FI but i want to move my alternator from under the PS unit.
This will replace the belt tensioner.
Old Oct 3, 2011 | 08:53 AM
  #202
ModularTurbo's Avatar
You should be ok with the Meziere pump, you won't need the tensioner.
The tensioning is done with the alternator.
Old Oct 3, 2011 | 08:55 AM
  #203
Originally Posted by chevymec
Its a 100 amp powermaster sbc alternator. Sorry I just saw this post. What do you need a pic of, just the front?
2 or 3 pic's should tell me what I need to know to help you.
Old Oct 3, 2011 | 10:34 AM
  #204
black06g85's Avatar
any idea on belt length without power steering?
only running the water pump, alt, and crank pulley
Old Oct 3, 2011 | 11:56 AM
  #205
I need to know 2 things, are you using the stock F-Body alternator? are you using the stock size crank pulley?
If you are using a under drive pulley I can't help you with a belt size as I don't have a under drive pulley to use to check belt length.
If you are using a stock size crank pulley and F-Body alternator I will find the right size belt for you and ship it with the kit.
Old Oct 10, 2011 | 10:25 AM
  #206
black06g85's Avatar
got the kit already from you. Stock alternator, and ati damper, but stock diameter
Old Oct 11, 2011 | 09:35 AM
  #207
00SLPSS's Avatar
Default alt relocation
I picked up my kit from these guys over a month ago. Decided beings I'm going to keep my car and not sell when I'm done dumping money in it, I wanted to upgrade to a nice alt that would last. Everyone was out of stock on the alt I wanted, but I finally found one and got it in the car, and upgraded all my wiring. I also hid a lot of my wiring, new alt exciter wire, etc, really pleased with the results.
I called rob prior to ordering and he was very helpful, and will answer all your questions regardless of how remedial, etc. The brackets came in quick and everything looked straight forward, I even gave rob a call just to double check that I was supposed to pull everything out with the old alt brackets. If I would of just done it, it was self explanatory, but I like to double check things. Left rob a message and got a call back very quick, although these guys don't have a huge corporation they make up for in their customer service. I'm not getting anything for free or discounted, or know these guys personally, I just wanted to give a good shout out when it's needed. Since the economy dropped I feel every place has gone down with service, and rob and chris will do what they can to help you out!
(and I know my engine bay is dirty, car wasn't running at time to clean it all off nice)
I can't wait to see the pictures of the full power steering kits. I hear word they are basically done, I'm just waiting to save up some more funds and purchase the kit. It's nice being able to work on little projects getting the car ready for turbo, it will save some time for when the build starts.
Old Oct 11, 2011 | 04:23 PM
  #208
Thanks for the compliment
Old Oct 11, 2011 | 10:52 PM
  #209
ZTwentyAteU's Avatar
I've put 2 on so far, this is a nice kit! $179 for something that just bolts right on is worth it. Thanks Modular Turbo
Old Nov 5, 2011 | 07:20 AM
  #210
bumpity
Old Nov 10, 2011 | 08:01 PM
  #211
dschmittie1's Avatar
Got mine today and installed tonight. Thanks Rob for the fast prompt shipment. I got it just in time to go to a track rental tomorrow and test it out for some low 9's passes.
Just an FYI for anyone that is looking for belt sizes Stock diameter ATI balance EWP and alternator only belt length is 50 1/8" or a Napa part number 25-060495
My only complaint is that the alternator hits my Breather on the oil fill cap
Old Nov 13, 2011 | 05:06 PM
  #212
How did your weekend at the track go?
Old Nov 13, 2011 | 06:08 PM
  #213
Yep ran a new best 9.5@147mph in a 3600lb pig. Alternator mount worked flawlessly
https://ls1tech.com/forums/forced-in...-firehawk.html
Old Mar 12, 2012 | 12:48 AM
  #214
shawnc16's Avatar
Bumping this for reference. Kwik performance "Hot rod" bracket on the right. The Kwik bracket sets the alternator up way to high.
Attached Thumbnails LSX alternator relocation kit-2012-03-10_13-20-36_91.jpg
Old Mar 12, 2012 | 12:54 AM
  #215
02sleeperz28's Avatar
Interesting. I'll have to get one of these soon.
Old Mar 15, 2012 | 02:33 AM
  #216
stealthrunner's Avatar
Wink
Just ordered one tonight for my LS1 powered rock Crawling buggy!!!I'll let ya know how it works in the dirt!!!
Old Mar 21, 2012 | 11:05 PM
  #217
you gotta post pics of that
Old Mar 22, 2012 | 09:48 AM
  #218
drumbo87's Avatar
How about a lower driver side kit ? I would buy that!
Old Mar 25, 2012 | 01:19 PM
  #219
Black Sunshine/ 00SS's Avatar
[QUOTE=Tramminc;15105326]
Originally Posted by nahasapeemapetalon
Got the (i think first bracket made)!
My mid 90's suburban alternator wasnt doing the job, voltage was always really low and my belt alignment wasnt very great.
I got a 145A truck alternator and used this Modular Turbo bracket. I have nasty nate fuel rails and just had to replace the passenger front rail fuel fitting with an NPT 90 to hose end fitting.
The bracket was well put together, seems really sturdy. Nice adjustable tensioner. No more belt squeal. So far so good.
I probably didnt need to modify the alternator back plastic cover but chose to for possible belt tightening.
14.0Volts FTW!! Nice work guys, thanks for the quick ship!
First thought was a gas leak at the 90 and spark from alt.
My thoughts also.. Looks extremely tight in that area, with the aftermarket rails. Looks like I'll have to switch to a fitting like in the pic to make mine work.
Old Apr 22, 2012 | 05:35 PM
  #220
PRAY HRD's Avatar
Looks great! But is there a price minus the belt? i have an slp crank pulley, meziere street pump, no a/c or p/s and a power master alt but i'd rather buy it and have it all set up and ready to go for when i need the belt.
thanks!
