Procharger P600B Kit - Stock LT1
Old 06-27-2011 | 09:32 PM
95-1LE-Z28's Avatar
Default Procharger P600B Kit - Stock LT1
Pulled the trigger on a used Procharger P600B Kit last week and it should arrive sometime this week. So far, i've bought a walbro 255 inline fuel pump and looking to buy 60lbs fuel injectors. The plan is to run about 8 psi of boost. I'm not sure what to expect in terms of HP but i think i'll be content with something around 420hp. I'm hoping the P600B being a small unit, it should be make things easier on the stock internals. BTW, my car just hit 56k. Since this is my first time getting into forced induction, i thought i'll ask in the forum what to expect and what to prepared for. Also will i need anything else in addition to the fuel pump and the injectors? Thanks in advance for your collective input.
Old 06-27-2011 | 09:42 PM
NemeSS's Avatar
aeromotive makes a replacement rr fpr for lt1 rails, might want to look into it.
Old 06-28-2011 | 07:04 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Take at look at our Formula LT1 at the link here. http://shop.brutespeed.com/Brute-Spe...ed-Formula.htm
It has a P-1SC but you should see somewhat similar results. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 06-28-2011 | 07:44 AM
95-1LE-Z28's Avatar
I'm looking through the classified section to see if i can get my hands on one. Thanks NemeSS.
Thanks Bob.
Old 06-28-2011 | 04:50 PM
jbrenner0188's Avatar
i have a 3.10 6 rib blower pulley new in box if interested,i got it for my p-1 but they sent me the rong shaft size..im told it fits urs..50$
Old 06-28-2011 | 04:52 PM
is that right bob? smaller then the p-1 shaft is the p -600
Old 06-28-2011 | 09:12 PM
99Ls1fever's Avatar
I think thats a nice little setup I would run the fu*k out of that setup I think it was a good choice. I dont know if you need 60's though thats a big injector for under 500hp.
Old 06-28-2011 | 09:37 PM
95-1LE-Z28's Avatar
The previous owner ran 60lbs injectors so I figured I'll stick with that. Am I better off with 42lbs or 50lbs injectors?
Old 06-28-2011 | 10:22 PM
99Ls1fever's Avatar
I ran 42's on a NA 408 stroker motor putting down 531hp for a few years with no issues. I would think 42's are more than enough unless you are planning on going crazy in the future.
Old 06-28-2011 | 11:13 PM
NemeSS's Avatar
eh.. just get the 60lbs. i ran em on my 500rw n/a car for years.
its all in tune. plus gives you room to grow. and not to have to buy nother set later
Old 06-29-2011 | 04:21 AM
MJs1FastSS's Avatar
42's will be plenty for your set up
Old 06-29-2011 | 06:00 AM
LTXBOI's Avatar
joseph whats up bro! 60lb keep them give's you room to grow,. Your tuner can allways bring the duty cycle down.
Old 06-29-2011 | 05:31 PM
95-1LE-Z28's Avatar
Hey CJ, I got back from lunch today to find two huge boxes sitting on my desk. The Procharger and the intercooler arrived a day earlier than expected. Thanks for shipping them out that quick.
Old 06-30-2011 | 07:40 PM
LTXBOI's Avatar
Originally Posted by 95-1le-z28
hey cj, i got back from lunch today to find two huge boxes sitting on my desk. The procharger and the intercooler arrived a day earlier than expected. Thanks for shipping them out that quick.
perfect!!!!! 1 more big box left...
Old 07-15-2011 | 10:58 PM
95-1LE-Z28's Avatar
My guys started the install this afternooon. I stopped by after work and my whole front end had been disassembled . I was worried my Prosport gauges were going to delay the install but, they arrived this afternoon with the A-Pillar. As soon as they get done tomorrow, i'm getting it towed to the tuners. Fingers crossed that everything goes smoothly with boh the install and the tuning. I guess I'm very excited to see the end results after everything gets daled in.
Old 07-16-2011 | 05:47 AM
LS1Tech Sponsor
If you leave the stock injectors in it until you get to the tuner, you can drive your car there. Just drive it at part throttle, do not go wide open throttle, not even once. You could drive across country like this and it won't hurt anything. It is also good way to make sure the blower belt is tracking correctly and that everything is working as it should be. Bob
__________________
Old 07-16-2011 | 06:57 AM
95-1LE-Z28's Avatar
I didn't know that. Thanks Bob. That's the beauty of this forum, I learn something new everyday.
Old 07-16-2011 | 05:07 PM
95-1LE-Z28's Avatar
Guys, i hit a little bit of a snag and I’m hoping someone can point me in the right direction. The kit is missing 2 of the 4.95 tube spacers circled in the image below. Does anybody know where i could buy just the spacers without a whole bracket and spacer package?
The other question i have is, should the head unit be touching the spark plug wires at all? Right now, it’s touching the wires where they're connected to the opti. Any input with possible images of how it should sit relative to the engine block and opti wires, will be greatly appreciated.Thanks.
Old 08-12-2011 | 03:24 PM
95-1LE-Z28's Avatar
Default Bob - BruteSpeed
Bob,
Thanks very for upgrading my air inlet order to next day shipping for no additional charge. The tuner received it earlier today and i really appreciate your promptness. Once again, thank you.
Old 08-14-2011 | 07:41 AM
LS1Tech Sponsor
Thumbs up
Originally Posted by 95-1LE-Z28
Bob,
You're welcome, thanks! Bob
__________________
