My Forged LS1 KYTP TC 78 Header build
So I've been doing this build for a little while now. We've been through quite a bit of relocation for the ABS module and had to cut the fuel lines from the filter and run braided steel line up to the fuel rails.
Stuff going in(big stuff anyway)
KYTP TC78 Stainlessworks Header AC kit(Tial bov and wg)
TU1 Cam
317 Heads
Forged ls1 with stock crank
FLT built 4l60e
Strange s60
Dual walbro pumps
60lb injectors
Block back from speed inc. Very nice!
![](http://i23.photobucket.com/albums/b354/wditton/c0d4c1d5.jpg)
Battery relocated to the trunk using one of those autozone battery box specials.
![](http://i23.photobucket.com/albums/b354/wditton/687a3cd3.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/20dac07b.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/d3092c8f.jpg)
317 heads slightly milled with a valve job
![](http://i23.photobucket.com/albums/b354/wditton/1a75bcba.jpg)
studs
![](http://i23.photobucket.com/albums/b354/wditton/9c4600cf.jpg)
TU1 Cam
317 Heads
FLT built 4l60e
Strange s60
Dual walbro pumps
60lb injectors
studs
![](http://i23.photobucket.com/albums/b354/wditton/ff76ef74.jpg)
Since the tubular headers are up and forward they hit the side of the ABS module where the crossover meets. I got some more pics. Also we had to bend down the brake lines forward instead of how they were which is straight up. This way nothing is hitting the header.
![](http://i23.photobucket.com/albums/b354/wditton/161df692.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/27fa4df4.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/87f47fa3.jpg)
Are you referring to the headers, crossover or dp? The headers sit out further than manifolds so things like the fuel lines and brake lines need to be relocated. We tried to flare the fuel line under the firewall, but that didn't work out so well so we ended up ditching the hardline and ran -8 braided steel from the fuel filter forward. The DP is 3" and the crossover I think may be 2.5". I'd have to measure to verify. Headers are 1 3/4"
My brother in law and I Made alot of progress this weekend. Ps relocation is complete and looks beautiful. Coil packs on with some protectors on the wires and tied up with stainless line. We may relocate the coils but hope this will work well for now. They aren't touching. Hooking up some of tge cold side and cleaning up the mess of wires and routing them where try need to go. Josh@kytp makes a pretty damn nice kit I must say.
![](http://i23.photobucket.com/albums/b354/wditton/6a2db59e.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/33daf916.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/c86e7f9d.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/d7d573e0.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/c59306c7.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/72bfde93.jpg)
I have no actual experience with the cross over pipes on LS1's, so my opinion doesn't count.
However, everything I have read is that anything 2.5" or larger on the cross over increases lag substantially.
Ya i was referring to the merge pipe between the headers and the turbo flange. But ok now that i look at it i see he did that because that was the size of the collector on the header. I know the pipe being a 1/2-3/4 bigger isn't really gonna change anything in the hp department just might make it .00098 seconds slower on spooling up. BUT then again that tc78 spools faster then a roots blower it seems like sometimes. So **** it might help!
hey man if you get a chance post a picture on your down pipe. On my setup it dumps on the drivers side and i wish i had room to run it to the back. It kinda looks like you did.
better pic of the header meeting the crossover
![](http://i23.photobucket.com/albums/b354/wditton/a98ecff2.jpg)
![](http://i23.photobucket.com/albums/b354/wditton/f274a877.jpg)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I don't have a pic of it, but will try to grab one next time i'm there. It dumps right under the firewall on the drivers side. my brother in law will eventually connect it to the exhaust and put a dmh cutout in as well. For now I'm going to dump it there to get it rolling. Do you have a pic of your dump?
Headers:
1 3/4" Stainless
3" Collector
Crossover:
3" Stainless
Down Pipe:
3" Stainless
Cold Side Pipes:
3" Aluminum
The StainssWorks headers these setups are based off of come with a 3" Collector. That is the sole reason for the 3" Crossover. From the Header collector to the T4 flange is less than 16" Per side. Hardly enough time to slow down the spool up of an already aggressive spooling TC78 turbo. Yes 2.5" pipe on the cross over would be ideal. However I do not like the Hard transisition from 3" to 2.5" in the collectors.
Will has done a very good job with pics and such of the install. This setup dies keep the Factory Accessories in the Factory locations. It does require some minor movement of relocation Concerning the ABS. I recommend junking it and getting an SMJ ABS Delete setup with a Line Lock. That is my personal preference though.
Keep up the good work Will.
1 3/4" Stainless
3" Collector
Crossover:
3" Stainless
Down Pipe:
3" Stainless
Cold Side Pipes:
3" Aluminum
It looks sick and honestly I'm debaiting on saleing my truck manifold kit to buy one of these off you with a t6 flange. Do you have a website with pricing and options?
And will all I have is a 3inch 90 deg that dumps straight to the ground. Its a little to loud for me though
That will give you an idea of the kits he makes. The only thing that caught me off guard was the stock hard fuel lines. They sit right up against either the dp or the header. My brother took it upon himself to run braided steel from the filter forward and cut the hardline out. We tried to cut and flare the fittings back under the firewall, but the main feed was bieng a pita. Otherwise all the accessories bolt right up. My brother is the man and helped me out a ton.
