Turbo LM7 Advice/Build List Nitpick (RX-7 Content)
Hey all,
This setup is going to go into my 1990 Mazda RX-7. It has a 400WHP LS1 in it now, but I want boost... thus...
I just purchased a turbo setup from a fellow RX-7 driver (comes with headers, downpipe, TC76, Turbosmart 48mm wastegate, etc.).
I was going to stick with the LS1 but I already have a low mile LM7 sitting around and I'd rather blow that up then my LS1.
Plus, the sale of the LS1 will pay for a lot of the new setup.
I really like the appeal of a "junkyard" build. Since this is a weekend car, I really don't care if I blow it up or not. Eventually I want a built 6.0, but not this go around.
The goal is to spend the least amount possible on the motor while keeping it semi reliable at ~10LBs of boost.
My tuner says I should get a smaller turbo - like a 70mm - so that's something I might change. We'll see - he runs that show.
Here's my tentative build list for you all to pick apart:
Motor:
5.3L LM7
ARP rod bolts
ARP head bolts
Z06 camshaft
Z06 pushrods
GM yellow springs
LS7 lifters
LS6 intake manifold
OE replacement water pump, oil pump, head gaskets, intake manifold gaskets, etc.
LS2 timing chain
F-body oil pan and all front accessories
Fuel:
60# injectors
255lph Walbro (already have)
91 octane
Turbo setup:
Turbonetics TC76 (thinking I might sell it and go a little smaller like a 70mm)
Turbosmart 48mm external wastegate
Turbosmart BOV (undecided on model)
Big FMIC (undecided on size/model/etc.)
Drivetrain:
T56 with Spec Stage 3 clutch and OEM flywheel
Ronin Speedworks 8.8" mount kit (with rebuilt Explorer LSD with 3.55 gears)
I'd like input specifically on my FMIC setup and my turbo size - though feel free to nitpick the whole deal. This setup *seems* to be tried and true![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Here's the car it will be in:
![](http://i90.photobucket.com/albums/k265/David343/IMG_0043.jpg)
And here's what the turbo setup looks like in the current car (a friend's from No Rotors):
Motor:
5.3L LM7
ARP rod bolts
ARP head bolts
Z06 camshaft
Z06 pushrods
GM yellow springs
LS7 lifters
LS6 intake manifold
LS2 timing chain
Fuel:
60# injectors
91 octane
Turbo setup:
Drivetrain:
![](http://i90.photobucket.com/albums/k265/David343/278496_10150328714545362_595540361_9542237_3906200_o.jpg)
I'm doing the same thing to my 88 RX7 vert! Pulling out the LS1 and dropping in the LM7. I'm going with the Patriot Gold springs, though. I also agree to the double walbro and to keep the 76.
Hey all,
The goal is to spend the least amount possible on the motor while keeping it semi reliable at ~10LBs of boost. A properly cared for 2005+ LM7 will take a hell of a lot more than 10psi and live if tuned properly
My tuner says I should get a smaller turbo - like a 70mm - so that's something I might change. We'll see - he runs that show. Keep what you have
Motor:
5.3L LM7
ARP rod bolts
ARP head bolts Spend the extra dough for studs
Z06 camshaft
Z06 pushrods
GM yellow springs Go with a double spring, the Patriots are cheap
LS7 lifters
LS6 intake manifold
OE replacement water pump, oil pump, head gaskets, intake manifold gaskets, etc. LS9 head gaskets seem to be all the rage right now, definitely use a MLS gasket
LS2 timing chain
Fuel:
60# injectors
255lph Walbro (already have)Two pumps or a BAP
91 octane
Turbo setup:
Drivetrain:
Do not go with a smaller turbo, there's no reason to. You'd be more likely to blow something with higher backpressure from a smaller turbo.
Motor:
5.3L LM7
ARP rod bolts
Z06 camshaft
Z06 pushrods
LS7 lifters
LS6 intake manifold
LS2 timing chain
Fuel:
60# injectors
91 octane
Turbo setup:
Drivetrain:
