Turbo LT1. What max coolant temp is ok?
what are you turbo guys seeing for max coolant temps or just crusing around town. my car is a fresh build and trying to get it tuned it is climbing up to 215-218 before i shut it off.
Mine is around the second mark on the temp gauge which is about 185 degrees. Cruising in cool weather will be around 170 degrees.
What does your cooling system consist of? Stock fans? 160 degree thermostat? Stock waterpump? When does your fans kick on and do they spin the correct way?
