Engine didn't last a summer/ new build time
so help your self out and stop trying to prove something that you have no clue about.
so far you have called me a lair and that im trying to black mail you
and now people you see why i didnt want to try to get Kurt urban performance involed. its just a waste of time for everyone
(PS the reason i use the full name is because the next time someone searches for Kurt urban performance. all of this BS will be pulled up)
i rest my case good night all
The truth will all ways come out. and what could of been a cheap fix for them is now going to cost them in lost sale.
so how did i find out the engine was bad? well the car started to smoke bad on decell and then all the time. there was oil in one down pipe so i was thnking turbo. sent that in to get looked it was fine. try alot of stuff than said F--- it took the engine out did some testing found the engine had some crazy leak down going on
things wrong
crank trigger was not clocked right (old issuse)
flywheel bolt pattern is way off (old issue)
waited for 4mos and the builder still couldnt get it back together after the trigger was put back on right. (old issuse)
i ended up putting it back to together my self and after looking at the clearance and calling the builder and asking if what i found was ok. he said "its fine"( piston to bore clearances WAY off)
sorry this is me venting
on to the bright side. i took the short block up the Billy Briggs. he stayed after hours until i could get up there after work. i took the engine and heads to him. we knock a piston out real quick took some measurements and he said he couldnt belive it didnt smoke from the start. he said turn around will be pretty fast . less than 4mos LOL
whats really funny is how much power it made still being this poorly built lol
so it s getting new Diamond pistons with the same CR and hoping callies will hook it up on a crank that should of never made it pass a quality check
a better cam as well the one i have is really small
ill post pics of all the crazy junk later. i hope next time on the dyno we should see a %20 increase in power
Help me understand the situation, since a LOT of stuff has been posted. Some of it is very confusing....
Please fill in the blanks for me....
1. You purchased a used engine from a seller on LS1Tech that was built by W2W. You did not buy it from W2W or Kurt Urban Performance?
2. Before you took delivery of the engine from the LS1tech seller, the LS1Tech seller sent the engine to KUP to inspect it for you? If so, who paid for the inspection, you or the seller?
3. KUP shipped the engine to you or did the LS1Tech seller ship the engine to you?
4. You installed the engine and found various problems with it. Reluctor wheel, crank, etc.
5. You call KUP and say the engine has problems and will he fix it since he inspected it for you or the seller or both before you received it?
correct
KUP is his sponor and re-built it fresh ready to go
KUP shipped it to me
yes sir
there was more posts in this thread but Todd pulled most of them. so it is kind of a mess now. im done with the bad mouthing. i hate threads like this. the word is out and im moving on with my New build and my life.
i think you need a better Manager
you never gave me one i dont think just like i never got the cam card i ask for
but im done now unless someone wants to drag this thing out any more
That should show anyone who reads this thread what really happened.
I will say I have NEVER heard a bad thing about KUP and have a good friend that helped me into the racing world that uses one of his assemblies with great luck as it's never had to been torn down in 3 seasons of HARD racing.
I think the little guy kinda got lost in translation here. I understand Kurt does lot's of big n ame race car's and that little projects that are done on the shops own dime usually rarely end up going the customers way.
Hope you get a good running engine in your car soon tom, I'm sure you'd love to drive it once.
give me a cal some time
