Full Weight 8 on a stock short block
http://neufamily.org/images/is300fil...arion%20sd.wmv
Jim's Lexus build is here:
https://ls1tech.com/forums/conversio...s300-swap.html
I drove it part way back to Omaha, it is a great platform for the LS swap.
It actually has 18 injectors, 8 gas and 10 e85. It transfers to the e85 injectors under boost. But run on the little gas injectors mostly.
So how are you guys liking that MSII setup?? I was really considering it when i was planning this build that im now.
The car is great man, and congrats on the new times. Looking very stout.
**edit** - I reread your reply and I think you are saying the sensor was maxed out shortly after leaving the line?
Whats your gearing and what rpm are you twisting it to?
To us in this site a Stock Bottom End means, a stock block, stock rods, and stock pistons along. Rod bolts and head studs are up in the air, but the general stock bottom end guideline is that each block will have stock rods/ pistons and crank in them. Mines has done it for 20k miles and since 2006. ALthought that's only 640rwhp it's help up fine with good gas at the track, and meth injection.
I wondered this...but to me it seems like it would be the same thing if you are injecting it into the intake manifold where the stock injectors are? Could be totally wrong though.
I can tell you I know about 5 serious contenders about to come out of the wood work for the stock block record, and I personally know two of them. one even runs the same megasquirt/msd6010 system as op.
definitely a fun time to be an ls1 turbo enthusiast.
atomic 6, question. how do you set up boost timing retard on the 6010?
Guess I will add a save my *** bar under the front incase it puts it on the bumper again.
so, i wanna see you raise the bar, but dont take too big a chunk out of it
cos thats just gonna discourage folks, especially us 4.8 guys so, i wanna see you raise the bar, but dont take too big a chunk out of it
