on3 turbo
Old Apr 28, 2012 | 10:23 AM
  #281
stangtrader's Avatar
I think my own cheapness is the cause I never put a check valve on. And at this point I'm sure that's what it is. Gonna put one on later today
Old Apr 28, 2012 | 08:05 PM
  #282
Sarg's Avatar
Check valve where?
Old Apr 29, 2012 | 11:10 AM
  #283
Oil feed line. Figured I wouldn't need one due to the way the line was run but was incorrect.
Old Apr 29, 2012 | 11:25 AM
  #284
Sarg's Avatar
Oh you did rear mount huh?
Old Apr 29, 2012 | 11:37 AM
  #285
Yeah. Didn't realize it would be an issue like it was.No biggie tho. Once I get off my *** and put it in I need to drive it for a bit and get the oil all burned off, the wot smoke clouds will disappear in time.
Old Apr 30, 2012 | 07:56 AM
  #286
lsxTAlemy's Avatar
what size turbo should i run looking to put a 370ci in my t/a with a front mount looking for 850whp 900whp
Old Apr 30, 2012 | 09:59 AM
  #287
killernoodle's Avatar
You aren't going to get that much from an on3 single. The biggest one they have is essentially the same as a TC76. You could easily do it with 2 of their 67mm turbos though.
Old Apr 30, 2012 | 11:00 AM
  #288
lsxTAlemy's Avatar
ok i know this might now be the place but what about master power? whats the biggest they have? i was looking for an o3 78 80 mm but couldn't find one. u just answered that for me. don't know if master power might have one. 78 80mm should be big enough for my power goal right ?
Old Apr 30, 2012 | 10:00 PM
  #289
fastsspr's Avatar
750rwhp can be achived from a on3 front mount in a 364 motor?
Old May 1, 2012 | 12:58 AM
  #290
You'd be hard pressed I think. Iirc master power dosent make anything bigger. For those power levels you guys may look at the Borg Warner s400 series turbos. On3 is decent but no ones really pushed one yet sounds like. I'm planning on turning mine up to 18 psi soon but I'm also a rearmount. So ill probly only be in the high 500s for rwhp
Old May 1, 2012 | 06:52 AM
  #291
RedRocketZ28's Avatar
I'm shooting for 600+ with my on3 LQ4 with a Speed Inc. TU1 cam. If I can't 600+ then I will be getting another turbo. I don't think I will have any problems though with a front mount setup.
Old May 1, 2012 | 07:10 AM
  #292
lsxTAlemy's Avatar
yea 346 but i have plans of putting an lq4 or lq9 370ci in the future.
Old May 1, 2012 | 10:26 AM
  #293
slow67's Avatar
Gingervitis Addict
Doubtful, they only seem to come with p trim turbines, or an even smaller turbine.
Old May 6, 2012 | 12:32 AM
  #294
ZTwentyAteU's Avatar
I should have some new results as we switched from the 70mm to the 76 .96ar ball bearing on3 a couple weeks ago on my buddies z28. We have been attempting to tune it at the track, but cant keep the car planted, it spins a LOT, even leaving off no boost it spins any tire we have tried besides a 28x10.5. Last outing it blew up the tq converter. This is a street driven stock 6.0 with a g5x2 and the 76 on 11lbs. Best we have mustered is 6.90s @105 with a 3-4 times pedal fest.
Old May 6, 2012 | 09:46 AM
  #295
HRHohio's Avatar
How is the spool time compared to the 70mm?
What AR was the 70mm?
Old May 6, 2012 | 12:35 PM
  #296
LS1NOVA's Avatar
Master Power makes a GT45 with a 76mm compressor and 77mm turbine. Its a beast.
Old May 7, 2012 | 12:46 AM
  #297
as soon as you hit it, the boost is there..almost instantly. The journal bearing 70mm took twice as long on spool time, it was the 1.0a/r. Before, you could footbrake it to right before it pushed through the brakes, and that was 0psi, then leave and it would make 9psi about 40ft out. Now, with just a turbo change, it will footbrake 9psi..or push/spin. Even leaving from 1800rpm and 0psi, it makes full boost just 10ft out.
I've actually ran the bb76 on a trans am with great results. I would buy another.
Old May 7, 2012 | 08:56 AM
  #298
HRHohio's Avatar
Good to hear. I have a rear mount BB T76 from them. Makes good power, but long spool time with the .96 AR. I talked to them and they will sell just the .81 housing. Going to order one today. Since it's a rear mount, that should really help with the spool time...I hope! LOL. Right now I'm foot braking to 0psi.
Old May 7, 2012 | 07:21 PM
  #299
I bet once it comes in it really gets down! I have used the journal bearing 76/.81 on a rear mount. It was in a 6 speed car, spool wasnt too bad, about 3500rpm on a completely stock motor with cats on it still. we basically bought a bone stock z28, pulled it in the garage one night, cut off the muffler, put a flange and turbo on, wrapped the rear section, dropped in a fuel pump and injectors and rolled out.
This car:
http://www.youtube.com/watch?v=Mf3WZ9L0IIU
Old May 9, 2012 | 05:17 PM
  #300
HRHohio's Avatar
Wow. All in a day? Pretty impressive. What did you do for cold pipe and oil system? No intercooler I take it.
Yeah, I get a few pounds boost in 1st, a few more in 2nd and a rocket engine in 3rd. Would like the rocket to ignite midway into 1st though. (.81 AR Housing is on the way, as well as 2 rolls of exhaust wrap.)
