on3 turbo
Old Jun 10, 2012 | 05:38 PM
  #321
fastsspr's Avatar
And your lq9 is completly stock?
Old Jun 10, 2012 | 05:59 PM
  #322
sleeper101's Avatar
Originally Posted by fastcars95
I have an on3 76mm and I find it a little laggy. I dont make much boost below 4000rpm on my LQ9.
I was thinking the boost would come on sooner ?
I would check for boost leaks. mine is full boost by 4000 rpm
Old Jun 10, 2012 | 06:16 PM
  #323
fastcars95's Avatar
Its stock except for a large turbo cam. I'll check for a loose coupler.
Old Jun 11, 2012 | 09:04 AM
  #324
HRHohio's Avatar
What's the AR on your exhaust housing? .81? .96?
Old Jun 11, 2012 | 09:33 AM
  #325
fastcars95's Avatar
.96 exhaust housing
Old Jun 11, 2012 | 09:40 AM
  #326
LS1NOVA's Avatar
Its definately not the turbo making it laggy. Something else is mismatched.
Old Jun 11, 2012 | 10:48 AM
  #327
HRHohio's Avatar
I'd have to agree. Check all your couplers for a boost leak. Also, check the exhaust side of the house for leaks.
Old Jun 11, 2012 | 05:31 PM
  #328
fastcars95's Avatar
I think its because I'm coming from a procharger. There is no waiting for boost.
Old Jun 12, 2012 | 02:40 AM
  #329
JoshuaGrooms83's Avatar
the .96 housing might be your issue. depending on whats going on, one guy switched form a .96 to .81 on his T76 and it made a world of difference. on rear mounts we have to be careful not to get too big on the AR unless you got a motor to push it or a spool valve to "trick" it. say a 383 and up range.
Old Jun 12, 2012 | 06:16 AM
  #330
Sarg's Avatar
On a rear mount you have a ton of chances to lose exhaust energy and heat. That 96 should be no issue. Maybe try doing a leak test? Not sure how easy it would be, but worth trying. That and check for any available places heat might be escaping.
Old Jun 13, 2012 | 12:26 PM
  #331
not to change the subject too much, what are you guys using to feed the on3 turbo? I have an oil feed flange with a .08 restrictor built into it. is that ok for my journal bearing turbo?
Old Jun 13, 2012 | 02:16 PM
  #332
fastcars95's Avatar
Mine came with a restrictor too. So far so good
Old Jun 13, 2012 | 02:38 PM
  #333
ok, i keep seeing restrictors emphasized on ball bearings. just was wondering about regular journal bearings.
Old Jun 14, 2012 | 09:13 PM
  #334
ledesordre's Avatar
Was told to run a -3an feed on journal bearing by on3 themselves.
Old Jun 15, 2012 | 09:06 AM
  #335
heres mine!! just came in the mail. installed the oil flange on it as well.
Old Jun 17, 2012 | 05:43 AM
  #336
fastcars95's Avatar
I'm running mine at 15lbs now and all I can say is WOW. Full boost just before 4k and it pulls hard
I'm looking for a decent priced turbo blanket for the On3. My turbo sits a little close to my rad. After a couple pulls my temps start getting up there.
Old Jun 17, 2012 | 04:45 PM
  #337
a-low's Avatar
Hi everyone im debating between a on3 76 or a ebay t88. From what ive read the on3 has a small turbine 64mm and the t88 has a 75. Its going on a 5.3 with a 4l80 looking for 600-700 to the wheels. Im doing ebay turbos to prove to a relative who says im crazy for thinking ebay turbos and a 5.3 can make that much power. Oh and ill be using a tu1 cam also. What say you?
Old Jun 17, 2012 | 05:08 PM
  #338
fist off, are you doing front or rear mout? depending on location a T76 with a 1.0ar would be a decent front mount turbo while the T76 with .81 ar seems to be the general starting route for decent power with these ON3 turbos.
FRom what i see the T88s seem to be sized strangly. alot of them have 60mm compressors and then massive turbine outlet. id imagine if you can feed that thing with enough air then i guess it would be ok, but with a 5.3 i think the T76 .96 would be a great starting point. ON3s is rated at 750hp. im sure you might be able to push it higher with a good amount of boost and tuning.
Old Jun 17, 2012 | 05:41 PM
  #339
a-low's Avatar
Sorry its huron truck manifold kit. Tha t88 i had in mind has a 75 mm comp wheel.
Old Jun 17, 2012 | 05:48 PM
  #340
HRHohio's Avatar
What are you guys doing for your fuel system. I seem to have run into a small wall with my setup. I've noticed several times that when I hit 9 psi, (top of second gear and at 5500 rpm) my AFR goes way high, like to 16!!! I immediately back off, but this gets me thinking if my fuel pump cannot handle the amount of fuel I need on this setup. I'm running an Aeromotive 340 (just one). I'm wondering if I'm pushing the boundary on it's capability for a single fuel pump on stock wiring and fuel lines.
What are the 600+ rwhp guys running for fuel systems? I'm thinking of going with the Kenne Belle Boost-A-Pump setup. Would rather not have to run new lines or add a second pump.
