on3 turbo
Old May 10, 2012 | 03:26 AM
  #301
Turb0Z28's Avatar
Originally Posted by killernoodle
I'm asking the guy right now what size orifice the restrictor needs. He seems to want to sell me one for $25. I was just going to drill my own.
any news on the oil restrictor
Old May 10, 2012 | 03:58 AM
  #302
Turb0Z28's Avatar
Originally Posted by Doobie52
Just a heads up for anyone thinking of going with the Modular Turbo hotside and an On3 turbo. It works like the two were made for each other! You can check it out in my build thread in my signature.
Same for me. I have Modular turbo and On3 76 .81ar
Old May 27, 2012 | 03:25 PM
  #303
fastsspr's Avatar
Originally Posted by ZTwentyAteU
as soon as you hit it, the boost is there..almost instantly. The journal bearing 70mm took twice as long on spool time, it was the 1.0a/r. Before, you could footbrake it to right before it pushed through the brakes, and that was 0psi, then leave and it would make 9psi about 40ft out. Now, with just a turbo change, it will footbrake 9psi..or push/spin. Even leaving from 1800rpm and 0psi, it makes full boost just 10ft out.
I've actually ran the bb76 on a trans am with great results. I would buy another.
And your talking about the on3 turbo?
what results you achived in your trans am?
Old May 27, 2012 | 06:28 PM
  #304
cgallagher04's Avatar
Who makes a well priced single turbo kit for 4th gens ?
Old May 27, 2012 | 06:31 PM
  #305
BLWN1's Avatar
On3 s is on the way, and cheap.
Old May 30, 2012 | 06:07 AM
  #306
sleeper101's Avatar
Here is a video of the 76mm on3 on my 5.3 240sx. 3200lbs 15lbs boost and I pushed a head gasket on this pass.
http://www.youtube.com/watch?v=eNdSZOa3FXA
http://www.youtube.com/watch?v=6VDMYPAK4Dk
Old May 30, 2012 | 08:50 AM
  #307
831jd's Avatar
what a.r?
Old May 30, 2012 | 09:05 AM
  #308
sleeper101's Avatar
.96 exhaust, I've been 6.23@119mph on this turbo spinning all the way with drag radials. I put the slicks on and loaded the motor since it finally hooks and blew my already leaking head gasket. that's with stock 862 heads and pump gas. I have a set of worked 862 heads I'm fixing to put on and get this thing in the 5's.
Old May 30, 2012 | 10:37 AM
  #309
68 SS's Avatar
I am considering a pair of the on3s anyone running a pair of them? If so what are your thoughts?
Old May 30, 2012 | 12:15 PM
  #310
831jd's Avatar
What trany and stall you running that beast moves!
Old May 30, 2012 | 12:24 PM
  #311
sleeper101's Avatar
Redneck performance powerglide w/ brake and there 3500 stall.
Old May 30, 2012 | 12:54 PM
  #312
BOBS99SS's Avatar
Captain Double Post
Cgal,look into huron speed,there kit is really nice and well priced
Old May 30, 2012 | 04:09 PM
  #313
fastsspr's Avatar
Wow congratulations man with those times.
Is impressive how far those cheap on3 turbos can push!
Old May 30, 2012 | 10:52 PM
  #314
Thank you very much . Can't decide between procharger or single turbo, both would be tons of fun.
Old Jun 3, 2012 | 06:33 AM
  #315
JoshuaGrooms83's Avatar
well i decided to go with the On3 T76 .81 turbo. its on its way in the mail. cant wait for it to get here
Old Jun 7, 2012 | 10:29 PM
  #316
fastsspr's Avatar
Interesting watching more people every day going with on3 turbos.
Old Jun 8, 2012 | 01:05 AM
  #317
Turb0Z28's Avatar
trans? and whats the 2 step set at?
Old Jun 8, 2012 | 07:24 AM
  #318
if we are gonna go with a cheap turbo, at least go with one thats had a decent reputation thats company is at least based in the united states and has a pretty decent customer service. they may not be the "highest of qualitys", pedegree'd turbos ever with papers and a breeding history, but cant argue with decent results.
Old Jun 9, 2012 | 07:23 AM
  #319
sleeper101's Avatar
Power glide and I'm leaving 3500 makes 8-10psi at starting line.
Old Jun 10, 2012 | 03:26 PM
  #320
fastcars95's Avatar
I have an on3 76mm and I find it a little laggy. I dont make much boost below 4000rpm on my LQ9.
I was thinking the boost would come on sooner ?
