on3 turbo
Old Jul 31, 2012 | 07:54 PM
  #361
LS1NOVA's Avatar
Originally Posted by red281gt
thinking of getting one of these for my set up. stock LQ9 with ls3 top end. heads have trace valves on them and a good mild cam. a buddy told me I want the biggest ar I can get for it. any input?
One would be stupid. Two would be stupidly awesome.
Old Jul 31, 2012 | 10:58 PM
  #362
red281gt's Avatar
why would it be stupid?
Old Jul 31, 2012 | 11:00 PM
  #363
HexenLord's Avatar
Because twin 76mm turbos on E85 is capable of 1500+ HP. Not to mention it wouldn't spool on a 5.3 until 5000 RPM.
Old Aug 1, 2012 | 02:03 AM
  #364
stangtrader's Avatar
Originally Posted by HRHohio
Any update on the source of the oil?
Yeah its leaking past the seals on the compressor side,idk maybe my lines on my exa pump are not big enough. I also recently got some results at the track. Im runni.g 2.73 gears with my 6speed so I leave like im leaving a stop light but I trapped 123 andgained
Almost 20mph from just before the 1000 ft mark to thru the traps. The car was getting retarded above 4000rpm in 4th
Old Aug 1, 2012 | 04:09 AM
  #365
red281gt's Avatar
who said 5.3?.I have a 6.0 LQ9
Old Aug 1, 2012 | 04:30 AM
  #366
red281gt's Avatar
anyone know how to contract this guy directly? I'm trying to order it asap but I want to get the biggest ar..phone number or email would be great.
Old Aug 1, 2012 | 04:46 AM
  #367
BottleFedZ346's Avatar
I think the biggest AR they offer is a 1.00
When I ordered mine he told me 76mm's all come with .96 backside....
Old Aug 1, 2012 | 05:35 AM
  #368
red281gt's Avatar
how did u talk to him? this is the one I want, says in description comes with .80ar and if u want to upgrade its $30 more for the bigger ar
http://item.mobileweb.ebay.com/viewi...id=92317468269
Old Aug 1, 2012 | 05:48 AM
  #369
LS1NOVA's Avatar
Because the turbine is tiny and on a 6.o with LS3 top end its going to choke and you wont even come close to full potential of the combo compared to if you chose the proper sized turbo.
Old Aug 1, 2012 | 06:07 AM
  #370
red281gt's Avatar
yea I know ur right on that, wr have a bullseye 80mm we was gong to use but I don't feel like cutting **** on the frame to make it fit cause Bitch is huge!.
Old Aug 1, 2012 | 09:23 AM
  #371
slow67's Avatar
Gingervitis Addict
Originally Posted by sleeper101
Yes the 76mm will make 700 no problem.
Not with that tiny *** turbine on a V8.
Old Aug 1, 2012 | 09:30 AM
  #372
AlterEgo's Avatar
so a ON3 76mm turbo is too small for a 4.8L???? What rpm on a 4.8 will it start to spool??
Old Aug 1, 2012 | 09:53 AM
  #373
1998T/A's Avatar
There's a phone number on his eBay page and his website. I called him directly to order my stuff. He's a great guy to talk to and he's super helpful.
Old Aug 1, 2012 | 12:11 PM
  #374
red281gt's Avatar
I just spoke to him he is a cool dude ordered the biggest ar he has for it which is 1.15 . said he has some single turbo kitsthat are going to come out for fbods and a front mount 88mm for our cars late fall. told him about this thread so he might stop by sometime.
Old Aug 1, 2012 | 02:59 PM
  #375
a-low's Avatar
Did he mention how much the 88s were going to cost?
Old Aug 1, 2012 | 04:33 PM
  #376
red281gt's Avatar
nope he said its gong to be a while till its out
Old Aug 1, 2012 | 04:34 PM
  #377
RedRocketZ28's Avatar
Thanks for sharing that man. I am going to attempt to run the 76mm with the .96 ar (thought that was the biggest they had when I ordered last fall) on my LQ4. It should make for a fun street car which is what I am going for. Wonder how much the 88mm will be? Might have to upgrade depending on how this turbo works out. Been working on the car for about 9 months off and on so I think it is time to kick this thing in high gear and get it done.
Old Aug 1, 2012 | 08:09 PM
  #378
T76s10's Avatar
Get a 70mm with .96ar. My 76mm with .96ar takes light years to spool on my 5.3 although I'm rear mounted. Depending on which cam you have you'll probably spool between 2500-3000rpm with the 70mm.
Old Aug 5, 2012 | 05:17 PM
  #379
red281gt's Avatar
I been speaking to him for a good while, he said the turbo set up should come out withing two months and the 88 probably by December.
Old Aug 5, 2012 | 05:26 PM
  #380
LS1NOVA's Avatar
Thats not the turbo's fault. Its the way you have installed it.
