on3 turbo
Old Aug 16, 2012 | 08:41 PM
  #401
Sarg's Avatar
Probably depends on the size feed line you have. I know BW recommends a -3 feed line on their T4 turbos, -4 feed line on their large frame T6 turbos.
Old Aug 17, 2012 | 12:13 AM
  #402
Ferocity02's Avatar
I'll be running -3.
Old Aug 17, 2012 | 02:27 AM
  #403
JoshuaGrooms83's Avatar
question on you guys running them already and specifically rear mounted, what kind of oil drain flange are you guys running cause the drain flange i got with -10an male end flange is too close to one of the bolts and i cant thread the an line on. do you guys rotate the compressor houseing or do you have some kind of flange that fits better?
Old Aug 17, 2012 | 09:02 AM
  #404
T76s10's Avatar
I ran -8an for the drain and took out one of the bolts on the compressor side to fit it on there. Since we have oil pumps to drain our oil, we don't necessarily need -10an line. I can take a pic of my oil drain later and post it up
Old Aug 17, 2012 | 09:59 AM
  #405
oh, im guessing with one bolt off id be fine with my 10an fitting, i was wondering what everyone else was doing
Old Aug 17, 2012 | 10:15 AM
  #406
Ferocity02's Avatar
I noticed the same thing. Looks like you may have to tighten the hose end onto the flange first, then bolt the flange to the housing, and clock the housing so a bolt isn't hitting the hose end.
Old Aug 17, 2012 | 01:15 PM
  #407
ren987's Avatar
you could be creating a boost leak. On my on3 turbo the compressor bolts go all the way through the housing I was going to leave one out also but instead I just removed some material off the head of the bolt and that worked fine.
Old Aug 17, 2012 | 01:35 PM
  #408
T76s10's Avatar
Thanks for letting me know. no wonder why i can't make over 5lbs boost. I'll check it asap when i get home. I thought for sure it wouldn't matter
Old Aug 18, 2012 | 01:39 AM
  #409
thats is a very good point. didnt think that. well, if i do run into a clearnance problem, ill defnitly go the "trimming" route over the leave it out one lol
Old Aug 18, 2012 | 09:03 AM
  #410
T76s10's Avatar
It didn't even make a difference weather it was out or not. I have one in there now just in case
Old Aug 27, 2012 | 07:16 AM
  #411
fastcars95's Avatar
My car just made 675whp with the On3 76mm .96 unit.
Best bang for the buck turbo
Old Aug 27, 2012 | 08:00 AM
  #412
RedRocketZ28's Avatar
What's the full setup? How much boost were you running? Did it choke out up top on your LQ9? I am worried about the On3 not being sufficient enough on my LQ4.
Old Aug 27, 2012 | 08:06 AM
  #413
fastcars95's Avatar
Here is my thread
https://ls1tech.com/forums/forced-in...o-results.html
I think its got more in it. Once I take care of a few things we are going to turn it up.
Old Aug 27, 2012 | 08:40 AM
  #414
Here is my thread
Nice man. Congrats! Makes me want mine done even more now.
Old Aug 27, 2012 | 01:30 PM
  #415
Ferocity02's Avatar
Seems like it ran out of steam early according to the dyno graph. It's a pretty small turbine for a 6.0L. Also I wonder if the backpressure in the exhaust is opening the wastegate even without the pressure line hooked up? Anyone?
I wonder if going to the 1.15AR housing will help much. I have the same turbo going onto my 5.3L soon, liking these results!
Old Aug 27, 2012 | 02:14 PM
  #416
Yeah, not an ideal turbo for a 6.0L. If it doesn't do what I want it to, then I will be upgrading the turbo next year.
Old Aug 27, 2012 | 02:37 PM
  #417
Here is my thread
NICE!! im not looking for anything near that but makes me feel better that the ON3 is up for the task. since im only looking for 8psi and 550ish out of my t76 ill have plenty on the table left when i decided to up the support mods for bigger power later. but for now a 550ish starting point with bone stock 98 ls1 is all im asking for
Old Aug 27, 2012 | 03:10 PM
  #418
fastcars95's Avatar
It only appears to run out of steam because it blew out the gasket in the merge pipe. Also One of the 3 bolts bolting it to the truck manifold was backed right off.
Old Aug 27, 2012 | 03:35 PM
  #419
Sarg's Avatar
Probably some pretty high backpressure too!
Old Aug 27, 2012 | 04:20 PM
  #420
tta656's Avatar
with your fitment problems are you using hex head bolts,or allen head bolts
