trying to down size turbo, need some help with physical sizing
so with that t3 flange i am trying to go with with smallest turbo i can polsibly do. im only trying to have 5psi. i dont really care for the extra boost and i am not trying to think about the future when i might build my motor. i just want the smallest one for now that i can just bolt up.
thanks
Man, sounds like your in a predicament, I'd honestly stick with the turbo you have now, and try to make it spool faster.
Just for example my PT7675(76gts) hits full boost between 3900-4300 rpm depending on weather conditions, timing, air fuel ratio, and what gear I am in, stopped or at a roll. Also if your car is a manual it will take longer to spool the turbo especially between shifts, if it's an a4 it will keep the turbo spooled from the moment you floor it.
