stock fans on a griffin radiator
has anybody modify a set of stock fans to work with the griffin radiator. I was thinking of getting a set of lt1 fans and making a shroud..
I personally would only run a oe type fan for proper air flow if its a street car. Why the small Griffin radiator? IMO the lower support should be modified and a radiator with a bigger core should be used. My radiator is 27x19.5x2.5 and fits perfectly.
Idk I just don't get why people reduce the vehicles cooling capacity.but you probly can make it work or use a Taurus fan
yea i tried about 5 radiators and fan setups over the past 6 years. i found that the fans matter more than the radiator. the taurus fan works better for me now. here is a pic of the taurus fan. nthe 106mm turbo takes up alot of space.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Stock fans on a griffin radiator... Works great. Its tight... but runs now and nothing has melted.
Mid build pics... but you can see it.
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/216184_10150563388095018_535410017_17904821_2413947_n.jpg)
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/196840_10150430444580018_535410017_17261982_7551343_n.jpg)
And my last build in it, some better pics..
![](http://i121.photobucket.com/albums/o216/green461/TransAm/DSCN1047.jpg)
![](http://i121.photobucket.com/albums/o216/green461/TransAm/DSCN1071.jpg)
![](http://i121.photobucket.com/albums/o216/green461/TransAm/DSCN1072.jpg)
Larger turbo sat above the fans.... this old setup of mine worked perfect.
![](http://i121.photobucket.com/albums/o216/green461/TransAm/DSCN1140.jpg)
