whats up with my dyno numbers? peak hp at 4600rpms
First run, i spun the tires on the dyno....
second run, i put some people in back for weight. made UNIMPRESSIVE numbers
NUMBERS: 531 rwhp and 629 rwtq. made PEAK horse power at 4500 rpms. i suspect valve float. doesnt matter.. i only did this as a before and after test. i am putting pistons in this winter, and i am doing some major head work.
the curve looks great until 4600, then it goes to ****... and that bothers me.
what's wrong guys?
spark blowout?
valve float?
sissy heads?
FYI, it's a 383 with home ported lt4 heads, single plane intake, blow thru carb, E85, GT42 T6 turbo, 4.5 inch exhaust.
what's wrong guys?
spark blowout?
valve float?
sissy heads?
previously this motor made 400/400 rwhp and rwtq with a different cam, and lt4 intake. I changed to a single plane intake, and a smaller cam for boost.
what the rest of the motor is:
home ported lt4 heads, basically cleaned up castings, and gasket matched.
comp 918 springs
gasket matched Vic Jr intake
C&S Blow-thru carb, running E85
383 rotating assembly. fully forged.
11.3:1 compression
cam card:
GT42 turbo, T6 divided housing. Turbo headers, 4.5 in exhaust to about the tail shaft of the transmission, then it divides into dual 3 inch
I wish I could claim I built the kit, but I did not. interia fab works in Arnold MO did all the turbo work.
It's all generic off the shelf mandrel bent stainless pieces on the hot side that were cut and fit to this kit.
