Anyone runing different ac condensors?
Old Oct 31, 2011 | 07:18 PM
SPRAYED 01's Avatar
Default Anyone runing different ac condensors?
So my life would be alot easier if my ac condensor wasnt in front of the radiator. I really want to put a slightly smaller one behind my fmic with a big puller fan behind it.
Does anyone know of a place that can make custom ones?
Or if I go to a junk yard would most gm cars use the same line connections?
Old Oct 31, 2011 | 08:08 PM
LSevil1's Avatar
Interested in this as well. I've considered moving it under the car with some 10" fans, just don't know about the angle and it's affect on the r-134 in it's liquid state.
Tim
Old Oct 31, 2011 | 08:37 PM
L92 fox's Avatar
I also would like to know lol.
Or if someone can chime into how they got their stock condenser to fit in front if the radiator with it stood up.
Old Oct 31, 2011 | 10:49 PM
tripblackls1's Avatar
I'm with the op , I want to put mine behind the ic , might have to have one custom made or hit the junkyard and find one that's the right size
Old Oct 31, 2011 | 11:39 PM
stangtrader's Avatar
I am running a stock one but my lower radiator support has been remade so I can fit a bigger radiator.but I don't see why it can't be made to fit with the stock lower support modified.
Old Nov 1, 2011 | 12:46 AM
vicouSS00's Avatar
I am interested as well I wasn't able to fit my condensor with the aftermarket radiator and specific altetnative condensor?
Old Nov 1, 2011 | 07:21 AM
SPRAYED 01's Avatar
I've been to some junk yards and seen the little civic ones. The interior of these little jap cars are probably about the same size as an fbody. I wonder if a small condensor with a nice dedicated fan would work
Old Nov 1, 2011 | 10:38 AM
LSevil1's Avatar
It's vital that the condenser be sized correctly with the compressor or the system will not work efficiently or at all. The life of the compressor could also be shortened.
Old Nov 1, 2011 | 11:03 AM
Tiago's Avatar
you can buy some random sized universal condensors on summit/jegs.
Old Nov 1, 2011 | 12:11 PM
willizm's Avatar
Thats what I did. I can't remember the name of it, but I bought a 12" x 24" condensor and plan on mounting that to the front of my radiator. I just have to get some custom lines made to hook it all up. My rad has low shrouded pullers btw.
Old Nov 1, 2011 | 12:13 PM
SPRAYED 01's Avatar
I did not know the of the condensor mattered that much. Ill look for one that takes a similar charge. how many pounds does an f body take?
Old Nov 1, 2011 | 02:44 PM
smokinHawk's Avatar
i have one that I was going to relocated similar like you are talking about but decided to not put the ac back in.
i would part with it
https://ls1tech.com/forums/parts-cla...l#post15169033
Old Nov 1, 2011 | 02:47 PM
Fbodys take 1.5 lbs of r134
Old Nov 1, 2011 | 03:26 PM
SPRAYED 01's Avatar
Is that a condensor or evaporator?
Old Nov 1, 2011 | 03:57 PM
Super Slow SS's Avatar
I was interested in this as well, I have seen it done on a twin turbo car done by a local shop, even asked what condensor they used and the owner didn't know. I am still trying to find out.
Old Nov 2, 2011 | 08:03 AM
smokinHawk's Avatar
the condenser is in front of the radiator, evaporator is in the black box area behind the glove box with the heater.
guess i had my info messed up
