4.25" throttle body to a 3" Intake Pipe
Old 12-12-2011, 09:13 PM
Wicked69's Avatar
Default 4.25" throttle body to a 3" Intake Pipe
I have a UMI throttle body and am using 3" for the cold side. I purchased a 4"-3" reducer but can't get the 4" side over the throttle body. I couldn't find anywhere I could get a 4.25 reducer. Is there anything I can do to get this reducer to fit or do I need to try something else?
Old 12-12-2011, 09:25 PM
1BADAZZSS's Avatar
Straight, 90? Check ebay. Look for 4.25 silicone transition
Old 12-12-2011, 10:08 PM
Wicked69's Avatar
Straight. Thanks. I was just checking on this site. I'll check ebay.
Old 12-13-2011, 12:19 AM
So.jerZ-28's Avatar
use a heat gun or blow dryer to enable the silicone coupler to stretch over it if needed
Old 12-13-2011, 12:22 AM
ZTwentyAteU's Avatar
If you cant get it, put a SMALL slit in it, heat it up, lube it up and pop it on
Old 12-13-2011, 05:18 AM
LS1NOVA's Avatar
http://www.racepartsolutions.com/products.asp?cat=38
Old 12-13-2011, 08:27 AM
Wicked69's Avatar
I got my reducer from racepartsolutions. I totally missed the 4.25. It is listed kind of by itself. I will try heating it up and a small slit as mentioned first. Thanks.
Old 12-13-2011, 04:56 PM
stevieturbo's Avatar
Why such a large TB ?
Old 12-13-2011, 09:54 PM
Wicked69's Avatar
You got me? It is a UMI 90mm and that is how big the opening is. I am using a vic jr intake, edelbrock tall 90 elbow and the 90mm UMI throttle body. This is on a twin turbo 5.3 running E85. I was told this was a pretty good match up. I got too good of a deal to pass it up. I got all the stuff listed above for less than $500.
Old 12-14-2011, 04:29 AM
Fair enough on the pricing etc.
But dont forget. You did state your IC piping is only 3". ie 76mm OD.
Your plumbing will be far more restrictive than the TB. SO chances are anything from 60-100% throttle wont actually make any difference to airflow into the engine.
Excessively large TB's just reduce throttle control. Although for drag cars etc that isnt really an issue I guess.
Old 12-14-2011, 07:56 AM
Wicked69's Avatar
Okay. You bring up a point. My turbo's are only 2.5" to the compressor so that was why I was going to use 3" intake piping. I could use 4" all the way down and reduce it to 2.5" with the silicone adapters. I could also use aluminum here. Would that work better?
Old 12-14-2011, 09:31 AM
05HD's Avatar
If it was mine, I'd do the whole cold side I/C piping in 4.25" and leave the hot side smaller.
Old 12-14-2011, 09:45 AM
LS1NOVA's Avatar
Absolutely no reason to use 4.25 cold side. Keep it a little smaller to keep the velocity up. Similiar to hot side charge pipes (2.5 or smaller). Id use 3.5 on the pipe to the tb just to make the transition a little less abrupt. I doubt the intercooler outlet is bigger than 3 or 3.5 anyways.
Old 12-14-2011, 01:39 PM
I certainly wasnt suggesting to use 4" or larger plumbing, that would just be ridiculous unless you're looking to go well into 4 figure power.
Quick Reply: 4.25" throttle body to a 3" Intake Pipe
