opening up ring gap to .028 cause excessive blow by?
Top ring .0024-.0028
Second ring .0026-.0030
Gapless rings are not conventional rings. They slide over one another. When they heat up, they don't touch end to end. The top just slides over the bottom.
The majority of your blow by typically does not come from your ring gap. It comes from your cylinder being out of round (Not a 100% perfect circle). This is why they make exhaust ports in race pistons. It takes cylinder pressure from the combustion process and forces that pressure to the back side of the piston rings. This in turn forces the rings into the cylinder walls creating a much better seal. You do sacrifice engine life though. But that is for race apps anyways...
Over all, you should not be opening up to a generic .028" ring gap dimension, but actually figuring out what your gap should be for your type of power application via the appropriate formula. This comes from your bore size. Not everyone has the same bore size. Therefore, not everyone will have the same ring gap.
To the above post. .0065" x bore would be on the larger side of the correct area (I would say .006"). Also, the bottom ring gap should be 20-30% larger than the top ring gap. This prevents the top ring from fluttering when exhaust gasses try to build up between the two rings.
Both the main ring and the secondary part have a gap and go into the bore the same way any ring would.
99% of stuff in an engine is give and take. There are very few exceptions to this. You make one thing better and there are draw backs. You can go forged, but it costs more money and you may get pistons slap. You can open your ring gap, but you get more blow by. You can open up the ports on your heads to achieve max flow, but low end torque will suffer. You get a big powerful turbo, but you have lag. Get a really well breathing cam, but emissions and idle suffer. The list goes on and on. It's all in what you are willing to put up with.
Search my posts, I give out info on my setup, also lots of other good info on here if you do some searching.
