Where does everyone mount their trans coolers?
Old Jan 16, 2012 | 10:12 PM
RedMilleniumZ28's Avatar
Default Where does everyone mount their trans coolers?
Where does everyone mount their trans coolers for a vertical radiator, front mount turbo, with intercooler, and A/C delete?
im planning on running 1 or 2 pusher fans so i was thinking in front or behind the intercooler?
Post pictures if possible...
Thanks
Kyle
Old Jan 16, 2012 | 10:20 PM
tt383lt1's Avatar
mine cooler is under the car about right under the driver seat. and it stays really cool with it right there.
Old Jan 16, 2012 | 10:44 PM
TX RED's Avatar
Post pics 383
Old Jan 17, 2012 | 11:31 AM
Packy's Avatar
I put mine to the near the passenger side of the front opening on my car. There is a good 4-5 inches between it and the intercooler piping so there is no contact between the two. It keeps the temps down under 200 degrees F.
Old Jan 17, 2012 | 04:26 PM
silver_82's Avatar
I have my trans cooler under the car with a homemade scoop, keeps it nice and cool, and out of the way
Old Jan 18, 2012 | 07:15 AM
speedracer5532's Avatar
I am also wondering where to mount a trans cooler. I have no room anywhere around my radiator with the turbo right behind the radiator and pusher fans in front of the radiator. Has anyone mounted it to the back side of the intercooler? I don't really want to mount it under the car because I would be afraid of catching on something you could run over.
Old Jan 18, 2012 | 12:20 PM
93BlackBeast's Avatar
Mine is under the rear of the car below the hatch area and is a cooler with a fan. I've got it triggered through HP tuners to turn on when the engine gets to 180. I don't have any pics but the routing is clean and simple, the tranny lines just go to the rear of the car instead of to the front. There is a gap of air also the way the cooler is mounted, so there is more than enough airflow. The car is in the shop right now getting exhaust or I'd go grab a pic for you.
Old Jan 18, 2012 | 12:26 PM
dville_gt's Avatar
I know its not an f-body (but is lsx powered), you can see mine is mounted in front of the intercooler, you can barely see it in this picture but it just slightly off center to the passenger side.
Old Jan 18, 2012 | 12:33 PM
chiaj144's Avatar
I've got a fox and I put mine on the driver's side right where the muffler used to be. It has a fan on it that comes on when the engine fan does. Works great so far.
Old Jan 18, 2012 | 12:49 PM
cjmatt's Avatar
what cooler are you guys running?
Old Jan 18, 2012 | 04:34 PM
Monte4ever's Avatar
I have a 82 Monte Carlo and I mounted mine vertically just behind the front bumper off of the intercooler mounting bracket I made. They sit about one inch above the bumper and around six inches before the stock radiator air damn so they should get plenty of air.
Old Jan 18, 2012 | 07:51 PM
tt383lt1's Avatar
dont worry mineis tucked up there pretty good my subframe connectors are lower than my trans cooler
this is my tranny cooler
http://www.ebay.com/itm/Aluminum-Tra...sories&vxp=mtr
Old Jan 18, 2012 | 08:18 PM
MattSapp95_T/A's Avatar
mine is right behind the intercooler and infront of the radiator... I have a pretty good gap in there...
Old Jan 18, 2012 | 10:57 PM
mounting them infront or behind the intercooler do you guys have problems with cooling either intake air for the intercooler(infront) or cooling the tranny(behind it)?
Old Jan 19, 2012 | 12:55 AM
skinnies's Avatar
I've done it on the radiator and in the back of the car on my rx7, testing showed only a 5 degree coolant temp increase with it on the radiator. If it goes in the back it gets a fan on it.
