View Poll Results: can it run 5s with the stock cam at 15psi
5.9999 maybe
43.48%
5.75 or even faster.
17.39%
No. low 6s at the best
26.09%
not no but HELL no. high sixes with mineshaft air
13.04%
Voters: 23. You may not vote on this poll
will it run 5s with the stock cam??proven -yes it will
Old 01-30-2012, 10:53 PM
Fbodyjunkie06's Avatar
Originally Posted by Nitroused383
I'm not an 1/8th mile guy but isn't a 5.9 almost a 9.0 second pass?
Funny you ask that. Ryank runs 5.90's and he has been 9.1x. It seems most turbo cars that run in the 5.80-6.0 range run in the 8.99-9.1x/9.20 range where nitrous cars that run 5.80-6.0 run 9.1x-9.3. N/A similar to the nitrous guys maybe a bit less in the 1/4. Comes down to power out the back door and converter efficiency too.
Old 01-30-2012, 10:55 PM
Originally Posted by 71 chevy
yay, another believer. everything i have read says it should be doable, even easy, but i dont see it happening often so that casts doubt.
how much would you say a stock lq4 with vic jr intake and good springs should make NA? about 375 at the flywheel?
i estimate the 4.8 was making 350 to 375 NA at the flywheel with the big cam
They make 320flywheel box stock right? What happened to the cam from the 4.8? Why not use it again? I'd say 350ish maybe 360?
Old 01-30-2012, 11:34 PM
71 chevy's Avatar
Originally Posted by seancarole
I was there with 4.8 and believe the 6.0 will bring in high 5's maybe a couple of times but really keep the boost around 10 or 12 and enjoy it before you blow it and then forge it then bring in the boost 25 and fly.
Hehe my next engine will be forged. after doing the math it adds maybe 1200 to the cost. not a bad expense that will allow me to turn the wick waaaaaay up
Originally Posted by Wicked69
I think you will run in the 5.70 range. Like already mentioned. You already almost broke 6 when on "paper" you shouldn't have. Also, people forget you are running E85 NOT 91 octane. That with a water injection....yeah I think you will get it. Shoot, I hope so. I am trying to dip in the 5's with my set up and mine will weigh 3600-3700 race weight. However, I am willing to go to 19lbs with a good tune. Hopeing I can also hit it at 15lbs. I am running a bigger cam though and my suspension worked great before. Not sure if it still will with the turbo's but hoping so. I had some low 1.30's before on 9" tires. I'm pulling for you.
Check out this thread. Similiar but with the 5.3 and dyno'd pretty damn good. https://ls1tech.com/forums/forced-in...ast-night.html
5.70s would be great. hell, 5.70s would be amazing, BUT the 6.0 would have to be making 400hp NA and thats the million dollar question. can i get 400 with e85 ,and intake only? the problem is you dont find any of these dynoed in performance trim but with the stock cam.
i would have to be 60' ing like you also. i think it will take 1.30s and have to be exactly 3000lbs and not more and maybe 5.70s would be in the cards. can you imagine even 5.90s with a STOCK cam?
about 320 stock is correct. 360s would be 720 at 15lbs so that would be enough to go 5s.
i nicked a couple of lobes on the old cam and decided to just chunk it.
why am i not getting a performance cam? im cheap.simple as that. also i want the low end torque of the stock cam so i can get up on the converter. and the best thing of course would be seeing peoples reaction at the track when you take a stock idling, quite car, and run 5s/low 6s.
this is one of my inspirations. hear how quiet that car is
http://www.youtube.com/watch?v=-_XkKhsTRRE
Old 01-31-2012, 08:57 AM
Yea Anthony's car's are plain bad ***. Especially that one, I love the engine bay in that car!
Old 02-01-2012, 09:44 PM
black98ws6ta's Avatar
Thanks! That car went a 5.79 @121 with the stock 5.3l cam in it, but it had more then 15 psi Alittle later it went a 5.64 @126 with forged pistons and rods/stock 799 heads/camshaft.
Old 02-01-2012, 09:52 PM
silver_82's Avatar
I have a perfect shape ls2 cam id sell ya that would have to be better than the truck cam right? 50$
Old 05-29-2012, 07:06 PM
71 chevy's Avatar
quick update - without a doubt it will go 5s at 15psi. this weekend with the wastegate springs out, leaving at 2 psi and making 5psi boost, it went 6.50s at 103.
heck, it might go 5s on 12 psi, still on the stock truck cam.
i love the ls1 platform, turbos, and ALCOHOL
Old 05-29-2012, 08:10 PM
chikn305's Avatar
That's impressive. I have basically the same setup going into my 87 firebird. It's a stock lq4 that will be run on e85. Good luck on the 5's
Old 05-29-2012, 08:14 PM
How is the alky tuning coming? You running M5?
Old 05-29-2012, 08:20 PM
71 chevy's Avatar
thank you buddy. good luck on your build. these things are beyond impressive.
it is coming great now. just tune on the rich side and let the computer slowly lean it out to my target. i still have it at 4.1:1 afr at wot and i heard they make best power around 5.2:1 so there is some left but im happy with it so i will let it stay a bit rich.
the alky tuning window is HUGE and it adds a very noticeable amount of torque.
Old 05-29-2012, 08:27 PM
I'd leave it there and let it eat. I help a guy with a alky o/l 275 car and he run's 3.5:1 AFR under full boost. Only if you got the spark though.
Old 05-29-2012, 08:39 PM
  #32
71 chevy's Avatar
Thats rich. i was worried about 4.1 being too rich but the engine doesnt seem to mind.
to answer your question, im running m1
Old 05-29-2012, 09:48 PM
  #33
Adam Connell's Avatar
Say what?? When did you switch to methanol? I still want to come see the car run. What are you running for a carb?? Let me know if you need a ton of M1, that's what we run in the Monster Trucks.
Old 05-29-2012, 10:04 PM
  #34
bad6as's Avatar
I went 5.9s on a single t4 80mm but at 120 mph
Old 05-29-2012, 11:55 PM
  #35
71 chevy's Avatar
you are definitely making some steam. ive seen cars run 5.70s at 120
about 2 weeks ago lol. im running holley fuel injection with a 4bbl throttle body.
Old 05-30-2012, 11:11 AM
  #36
thefastlife's Avatar
I'm just putting my numbers in for the fun of it stock shortblock 6.0 epp cam vic Jr and leaving on no boost cause trans brake was broke went 6.20 at 124.45 and converter was junk so coasted to a 9.66 at like 126 I think I 60 ft 1.76 on foot brake
Old 05-30-2012, 11:12 AM
  #37
So imo 5.99 with a good 60 for him could happen pretty easy
Old 05-30-2012, 04:21 PM
  #38
If you have the spark to allow the fuel it works fine. If not that's a lot of fuel to be in the chamber and not fire
Old 05-30-2012, 06:25 PM
  #39
overhere's Avatar
cam only lq9 was running 5.7@122 @ 15psi
Old 05-30-2012, 07:31 PM
  #40
Wicked69's Avatar
Damn....I am way behind the power curve. Way to go 71 Chevy. I hope to have mine out not this weekend but next weekend. My car was running way too fat and now its actually E85 instead of E70. So I am hoping with the same tune it will pick it up a ton.
Quick Reply: will it run 5s with the stock cam??proven -yes it will
