Quick Procharger Bracket questions
On the tensioning procharger pulley, the one that is adjustable to vary the tension on the belt, does only one bolt attach to the pulley or am I missing one? It is the pulley circled in red.
The reason I ask is that it had worked loose and was rubbing on the main serpentine belt and the bolt that I pulled out that attached the pulley was about 3/4 of an inch long and didnt really seem up to the task of holding a pulley on.
Thanks in advance, Im getting the bird back runnning after sitting for a year.
there is another bolt located behind the tensioner pulley, but only one that secures to the bracket. I'm not sure what size the bolt is though.
