Turbo Firehawk build up V 3.0 AES 385 and S88
Old 10-30-2012, 05:31 AM
  #321
dschmittie1's Avatar
Originally Posted by LSXFORMULA99
pump gas? what kind of timing? and who did your converter? My first 1/4 mile run with my car was a 9.6@ 126 coasting at the end because the converter is to loose. I want to run 8s and think a custom converter will do the trick
E85 and about 21 degrees of timing IAT's where about 144 on that 8.89 pass. I am tunning a Yank 3400 stall. 1/8 miles number where 5.72@123mph
Originally Posted by rotary1307cc
that thing was on the rise bigtime
too bad you didnt get the full thing
i was curious to see where it was peaking at and dropping off at
Yeah the thing was pulling hard til it fell off. You could even feel it in the car on the dyno. I could never reallyfeel it on the street or the track. AFR and timing where good so I am sure it wasn't just a dyno issue
Old 10-30-2012, 03:08 PM
  #322
Burrhos's Avatar
Badass build. thanks for sharing. I just read all 17 pages. Nicely done. What's next? Trying to go deeper in the 5s?
Old 10-30-2012, 04:09 PM
  #323
I guess my goal for next year will be to will be to max out my chasis cert and run an 8.5
Old 11-01-2012, 06:59 PM
  #324
Well now that things have settled down after Sandy came to town and got things a little wet around here. 10" of rain in one day and my house and a nice wet basement
I drove the car into work today to up it up on the lift look somethings over and put some coolant in it getting prepared for winter. I found that I did to a little bit of damage to the car on the wheelie. I bent the rack mounts on my BMR k member
Not bent bad but enough. I think I am just gonna put it on the alignment rack and see how bad it is.
I also was looking through the logs and my dyno sheet looking for some reasons for the odd things the car has been doing and the car falling on its face over 5500 rpm. I found that the PCM grounds on the back of the head were loose I am hoping this explains the MAP readings dropping out and the rpm readings jumping to 13,440 rpm during a pass
If the weather is good I think I will be heading back to the track on the 10th to try and best my 8.89 pass.
I also finnally for around to putting my Firehawk decals back on the car
Old 11-01-2012, 11:17 PM
  #325
Cam72aro's Avatar
At least it didn't crack the oil pan, right? lol. Its awesome that it has run in the 8's without turning the boost way up. I will be happy if mine runs in the 9's.
Old 11-01-2012, 11:43 PM
  #326
bad6as's Avatar
Dan I know you don't want to spend the money but ide hate to see you starve this bullet for oil on hard launces. Bobby extended his stock pick up, I went with the moroso pan. Not to many people talk about it but in my research 60fts in the 1.3s or faster, the stock stuff is sketchy.
Old 11-02-2012, 05:42 AM
  #327
I did put that improved racing baffle in the stock pan. I might switch to something better later
Old 11-02-2012, 05:43 AM
  #328
Your 408 should easily run 9's
Old 11-02-2012, 08:58 AM
  #329
Cam72aro's Avatar
I hope so. Honestly that's all I hope for. My car is heavy and doesn't have a trans brake. Your car is damn fast. It's faster than a lot of trailer cars.
Old 11-02-2012, 09:00 AM
  #330
Now I haven't driven my car to the track and made a pass in years. Breaking **** 55 miles from home sucks. Also now being on E85 I don't think there is any E85 close to Cecil that I could refuel and go home.
Old 11-02-2012, 02:21 PM
  #331
SKULL's Avatar
where are you going on the tenth to run?
Old 11-02-2012, 03:09 PM
  #332
There is a rental at Cecil
Old 11-02-2012, 08:05 PM
  #333
Cam72aro's Avatar
I ran my car on e85 with the f1a for a little bit and didn't like the limited numbers of stations. There is one by my house and I carry the laptop with me, but didnt like being limited. I also hated the gas mileage out of it too. I am back on 93, but with methanol so results should be similar. Of course if I go to the track I might do the e85 methanol deal. I gotta get this trans back together first, lol. Trailering the car is smarter, wreckers cost money.
Old 11-02-2012, 08:50 PM
  #334
2.5T_/<ouki's Avatar
damn such a nice build
Old 11-06-2012, 08:23 PM
  #335
Well I just paid for my spot in another rental on Saturday. Weather is saying a high of 56 so that is about 15-20 degrees cooler than when I ran the other week. I am hoping I got all my bugs worked out and I can make some more good passes
Old 11-11-2012, 09:28 PM
  #336
And it went a little faster
https://ls1tech.com/forums/forced-in...k-outting.html
Old 11-12-2012, 07:54 AM
  #337
Y2KFirehawk's Avatar
Great video, Dan. That damn thing moves and and still looks great doing it.
Old 11-12-2012, 07:56 AM
  #338
Thanks
Old 11-12-2012, 04:09 PM
  #339
SKULL's Avatar
Question
Edit Nevermind.
Did you figure out the reason it fell off at 5500 I don't remember if you said it did or not
Old 11-12-2012, 07:19 PM
  #340
Originally Posted by SKULL
Edit Nevermind.
I think it was a ground issues. I need to get back on the dyno to check
Quick Reply: Turbo Firehawk build up V 3.0 AES 385 and S88
