Another Rear mount build, but it was coming anyway :)
#261
sith a little triming the bumper is back on and everything is hooked up. drove it down the road and back to check for any scrapping. had one t-bolt cocked alittle at an sngle so that was scaping occasionally. but now i think i got it all straighten out.
found a little leak this mornign on the oil pump where the 3/8 npt to 10 an male couplers were. needed alittle sealant on the threads on the NPT side to keep the oil from seaping through. got that sorted out.
i sis dint something interesting and i might need to get a second opinion on it, but i had a nice helping of oil come out the under axle tube i think that was due to me parked on a back incline so al the oil was sitting in the turbo after shut down. that and checking for leaks. im making it a habit to turn the key once or twice to help suck out any extra oil thats it it before parking. its in sink with the oil fueul pump so when ever i turn the key the oil pump primes with the fuel pump. it quite a loud little thing outside the car. Inside the car us pretty nice again. i can hear myself. i noticed that its actually very docile inside the car again my wife said she'd actually ride with me again lol
well i tucked up so vaccum tubes from the wastegate and freshair line with some more zip strips, installed the AEM methanol kit (real easy actually), and clocked the turbo a bit to not have the outlet pointing down so much. im gonna try and get ti even more tucked up there when i get it on a drive on lift so the axle has load on it.
right now this thing doesnt even sound like a turbo car lol just sounds like a V8 trans am lol id image if i got on it on the road it wuold sound alittle more like it. but im not testing any waters yet until it gets tuned.
so for now all i have to do is install the 60lbs injectors, switch the 4lbs spring with the 10lbs spring(or both), hookup the true return line, trouble shoot the methanol system, and get an oil change and keep an eye on anything that out of the ordinary like oil leaks and blown couplers AND GET A TUNE lol
#262
oh and i guess the stock FPR is probably on its way out because the fuel pressure is still at 70psi at idle lol
oh and i got a little boost -5 psi on the boost/vac gauge lol it got closer!!
#263
and DAMN! does this thing sit low, and i tucked it up under there lol im wondering if i might do the heater hose mod on my rear lowering springs while still keeping that isolator in there to gain a little clearance in the back lol
#267
yeah the vogtland springs kinda have something to do with that. i gotta see if i can adjust some couplers to tuck it up in the back and the front. the rear is the worst though. not sure what i can do other then putting the stock rear springs back in it really dont want to do that. looks like i might have to make the over axle hoop for some clearance...
#268
ug, still trying to trouble shoot the AEM injection system... still giving me issues.. cant seem to get a good 15amp trigger source.
on a good note, i removed the licsens plate area so now its wide open for some fresh air
witht he cover on...
... and without
looks pretty good. without fogs is kinda growing on me, although id still like the option of having them...
... and without
#270
yeah i gotta do somthing but i gotta get it on a drive on lift to see what i can do. i cant seem to push the axle up high enough with out putting the entire car up off the jacks lol if i clock the compessor a tad and the turbine housing a tad i might gain a little clearnace. ill have to see.
sound wise its sooooo much quiter now lol i actually wanted ti quiter since the flowmaster had a hole on the bottome of if and was resonating sound all through the cabin. id have a headache after a 30min drive. sounded pretty mean at the track though lol even if it only did 13.9s LOL thats why i call it angry bird lol
ill get an idle and slight rev video clip of it.
that damn AEM injection kit is really buggin me.
anyone have any recommendations on where to wire the trigger wire? i think its casueing the isse since its getting more then 15amps i think
#271
A lift won't change anything. Simply disconnect the axle side nut on each shock and slide them out of the way then drop the axle enough to take the rear springs out. With the springs out you can jack the axle all the way up to the bump stops with only gravity as resistance. If I remember correctly you don't even need to remove the sway bar or track bar, but I'm not sure on that bit.
#272
im not talking about a regular point lift, im talking about a full drive on lift where i have the weight of the car as it sits while driving. that way i can look it correctly to judge how to get everything to sit right. i dotn need to drop the axle lol i need to have the weigh of the vehicle to load up the suspention
#273
#274
yeah, still trying to figure out that damn AEM wiring. its pretty simple but not understanding why its not triggering. where do ya'll hook up the trigger wire on ya'lls methanol kits?
#278
yeah, when i get alittle more time im gonna try and get it tucked up higher. thats also why i got the drain kinda angled to the back. im gonna see if i can get a drain thats closer to the turbo
#279
http://www.ebay.com/itm/190747513577...84.m1438.l2649
think i found somthing to tuck up the oil return line on the turbo, anyone use this before?
