Another Rear mount build, but it was coming anyway :)
#442
The issue is not with the key. The issue is that the design of the wiring from the ignition to the VATS runs in the steering column. The wiring bends every time you turn a corner. For some reason, our cars are prone to wearing that wire out in a certain spot. When that happens, the first sign is Security light (because the resistance is different on the thinner wire... I think). Eventually, the wire breaks from the back and forth bending. When that happens, you have to get towed and either replace the whole ign switch or solder in a resistor and bypass the ign wire to the key. Better to do it now than get stuck and have to do it later. Mine left me stuck after work 3 times before I was made aware of this issue. That was on my first car (2000 V-6). When it happened the first time on this one, I had it taken care of right away.
Another 2 threads that may be helpful to you: https://ls1tech.com/forums/lt1-lt4-m...de-please.html
What resistor do I need?: http://www.vatskey.com/vats/lostvatskey.htm
Glad you've got BOOST! LOL
Congratulations!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
im thinking I might have that done next time I go there. I can still use ,my keyfob right? the car just wont care if the the key is chiped or not right?
#444
No worries. I did it on my 72 that I used to have. Have done it on several cars with key problems. I had a customer that brought me a pos car that was a pieced together from his other car that was totaled. He ran a wire from the vats module to his old key and had it visegripped to it. It was hillarious. I turned it off and he was thrilled.
#446
Come to think of it, I don't think I have the key to the steering column for the 4th gen. Hmmm. I may be going with a push to start setup in that car (Secured RFID of course).
#447
got to see 9psi this morning. car still runs great. going to see if I can get a final tune next week Friday. unless I can squeeze it in this week which I doubt. also gonna get a new scavenger. this one I think just cant keep up. still getting smoke out the exhaust and I think some oil on the intake side. I park the car nose down so I keep most of the oil by the engine but I still think I need a better oil pump.
#449
Sorry, havnt updated in a awhile.
So far I get 9psi pretty consistently. once warmed up the car pulls hard! I break traction when it kicks into 2nd lol time to invest in some NT05s lol
smoke has actually subsided so I think the oiling issue is fixed but I am gonna get a turbowerx pump eventually to have a little more piece of mind. still havnt got the final tune yet. gonna see if I can get it tuned next week Friday. been really busy around the house and doing other stuff. car still feels great. im assuming the tuner has the car set very rich to be able to be boosting without having any fine tuning done. cant wait to see what numbers I can get. still have lots of adjustment left in the MBC so 12psi is very possible![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
turbo spools nice and you can hear it now
#452
front mounts wont have as much of the "turbo" sound as a rear mount will. less exhaust to go thru unless you do a bumper dump or something similar but for sure you can here it when I get on it. first you get that V8 muscle car sound and then the turbo takes over
its pretty bad *** lol cant wait to get a video of it on the dyno and at the track
#454
yeah I know. everytime you think you got it, something else pops up.
as for the tapping, I believe it was a 1/8 NPT into 4an adaptor fitting on the oil block for the feed.
decided to get a brand new cheapy scavenger pump to see if the current pump is on its way out since it was used. it also sounds kinda like it sucked something up and the gears arnt "smooth" sounding while running. although I don't mind, but I don't want the gears to get stuck for some reason and then no oil. plus its good to have a spare pump for just in case after I switch out the old one. next tax season ill get an exa-pump but for now these cheapys are doing their jobs. id just like a little less oil on start up and prolonged sits between runs.
I might be sneaking the car into the dyno this Friday. still waiting to see if they have room and time.
#455
#456
still waiting to get dynode, they are backed up in the tune shop something fierce and since my car is about 80% there, rich if anything, im not too worried about it for now. havnt gone to race it anyway and since the turbo doesnt start spooling until 3000+ rpm, its not a big worry.
What I am doing today was inspired by a felloe member here,
im going to put the long charge pipe up into the rocker panel and up over the driver tire. Hides there pretty well and will get my low pipe under the K-member form draggin on the damn ground. that's the only pipe that hits anything. even the long charge pipe doesn't hit anything other then big speed bumps. so here goes my inprogress build lol
#457
oh this looks SOOO much better!! got the long pipe up in the rocker. everythings hooked up and in their right place. need to get a few more extra clamps but I even managed to get the axle hump in there so now I have almost all under car clearance. need to tuck that damn turbo up higher again though. heres a few pics. ill post more of the final product later.
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050070_zps14875f4c.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050071_zps35533efe.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050072_zps4af70b3c.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050073_zps242d418f.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050075_zpsca51166b.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050077_zps4f71a5b3.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050078_zpsa6ef4289.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050082_zps49d2bac3.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050084_zps9193d393.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050085_zps3f3a92a2.jpg)
#458
now mind you these were in progress pics so it still had the old charge pipe routing that is now gone. also finally got rid of the AIR pump and its mounting bracket while I was in there lol so I lost a couple pounds and gained some clearance.
I got the wheel well piping tucked up better now that its all clamped into place.
Now all I need to do is get that better pump in there, put some clamps on a few couplers, and brace up the turbo a tad.
#459
and pretty close to final product. im gonna see how I can get my wheel well splash guard can go back in there.
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050090_zps114148e4.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050089_zps7fb4e09b.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050088_zps3e2ac31b.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050087_zps0702cce5.jpg)
![](http://i535.photobucket.com/albums/ee357/JT_Grooms/P1050086_zps832c92da.jpg)
as you can see, my turbo is dangerously close to the ground.... again
need to get a brace to help keep it tucked up against the body.
part of the problem is the pan hard bar rests on the snout of the turbo when the car is raised. I also noticed some pretty scrapped up couplers prior to the dissaembly so im sure those could have been a source of minor boost leaks
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#460
and done lol
tucked up my turbo I can now fit my entire fist under the turbo and the ground![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
fixed up some loose wrappings, and re-clamped all my loose couplings. I secured the turbo up by some cheap exhaust straps on the drivers side rubber hanger and then strapped the turbo up directly to the panhard support rod
I also used a stainless steel flexpipe over the wheel well. not sure how this will hold boost yet but tucks up better over the wheel without rubbing. the original design was rubbing the 3 couplers above the wheel on mild bumps so ya, a little more clearance was in order. I also supported the tubing up so that it stays in place over the wheel so it doesn't fall. im thinking of ovalizing the over wheel piping to gain some more clearances.
