Votech question
Old Mar 27, 2004 | 10:08 PM
  #41
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I wanted to see if we could make a lot of power with a stock displacment engine.
Old Mar 27, 2004 | 11:08 PM
  #42
SSC5R's Avatar
WARNING! Bad Seller Alert
So do u think its a good idea going with bigger ci or stay with the 346.
Old Mar 27, 2004 | 11:19 PM
  #43
SSC5R's Avatar
Pro Stock John, should I just go all out and go for the YSI-Trim? Do u have any pic's of you're setup. I would like to order my head unit this week. my goal is to have at least 800 to the tires. I know thats alot of hp, but if Im going to spend the money; I might aswell do it right the first time. Does the ysi fit like the G and T-trime or does it go in a diff. location? Thanks for you're help.
Old Mar 28, 2004 | 07:52 PM
  #44
Got Me SOM's Avatar
his is a race only setup. you don't just jump into 800 hp car and expect to drive it around like nothing.His car is built to do 8's. He had to have a lot of custom work as well it isn't exactly a bolt on kit.
if you got a lot of money go with a built bottom end and the vortech g trim, you should be in the 600's with 12 lbs. Any more boost than that will race require race gas and that's not cheap and takes away from the true streetness of your motor.
You can wait for the AFR heads to come out and combine that with a blower cam and that should be plenty. You shouldn't be concerned with hp numbers, that's ricer logic you should be concentrating on et or mph then go from there. It doesn't take a lot of power to go fast. A lot of it has to do with suspension, ie getting all that power to the ground. Spinning while a stock ls1 is walking away from you is no fun.
Old Mar 28, 2004 | 09:22 PM
  #45
SSC5R's Avatar
Thanks for the heads up. I have a set of AFR's 225 on the way. This motor is also going to be build with forged parts and it going to be a solid roller. This motor is going to be built at SAM. They are the best at what they do. Are NA LS1 hit 751 and no one has done this yet. So in other words I have no worries on their judgement. I also have conciderd all of these facters which is why Im building my suspension. Thanks for you're help.
Old Mar 28, 2004 | 11:17 PM
  #46
LS1Tech Co-Founder
If you stroke out an LS1 add $2000 for a stroker crankshaft.
I did not stroke my engine because I wanted to see what I could do with stock cubes.
If I were to build an engine on the side it would be 8:1 and would have AFR heads, and those would be the only deviations from what I have now.
Old Mar 28, 2004 | 11:35 PM
  #47
SSC5R's Avatar
I have a 4.00 Callies Crank already. Need to buy a set of rods and pistons. Not sure if go with JE or Ross. What would u get. Thanks for you're help.
Old Mar 29, 2004 | 12:23 AM
  #48
LS1Tech Co-Founder
I like the great service we've been getting from Diamond. I had a set of JE's in the past (past motor) and they took a long time.
Old Mar 29, 2004 | 01:18 PM
  #49
SSC5R's Avatar
JE does take a long time, I don't want to wait that long so I'll go with the Diamond. I was thinking of going with a Carrillos Rods but I hear that the Eagle Rods are very good to.
Old Mar 30, 2004 | 06:49 PM
  #50
SSC5R's Avatar
SO do u think I need to go with a T-trim
Old Mar 30, 2004 | 07:07 PM
  #51
stealth's Avatar
see my YSI setup at http://www.hollowayllc.com/stealthindex.htm.
Old Mar 30, 2004 | 07:30 PM
  #52
LS1Tech Co-Founder
I think that you might want to get a T Trim, but you might want to also ask jsnee@vortechsuperchargers.com for his opinion too.
Old Mar 30, 2004 | 09:28 PM
  #53
SSC5R's Avatar
Thumbs up
Thanks for the info guy's. Man that SS is one bad mother rocker. What would it take to do something like that?
Old Apr 1, 2004 | 10:03 AM
  #54
stealth's Avatar
I will update those photos in the near future to reflect the ongoing mini-tubbing, new 9-inch Ford, and new blower piping, which will route over the top of the radiator directly into the maf and tb.
Old Apr 1, 2004 | 10:22 AM
  #55
smokinHawk's Avatar
alot
or you could buy it from him if he's still selling it
badest ls1 (well lq4) around.
Old Apr 1, 2004 | 10:33 AM
  #56
stealth's Avatar
I'll still sell it.
Old Apr 1, 2004 | 02:07 PM
  #57
SSC5R's Avatar
By selling you mean the whole car right. I would consider buying your charger.
Old Apr 1, 2004 | 11:26 PM
  #58
SSC5R's Avatar
The guy I bought the charger from gave me an extra pulley. The only thing is I nor he knows what size it is. He said it gave him 14lbs. How do I go by telling what size it is? Thanks for your help
Old Apr 2, 2004 | 08:50 AM
  #59
driftpin's Avatar
Call the company that made the blower with the size of the pulley and the model of blower and what it's going on and they can tell you what approx. lbs it should put out. If you have changed crankshaft pulliies you will need to give them that measuremnet too.
Old Apr 2, 2004 | 02:36 PM
  #60
stealth's Avatar
THe entire car.
