What heads are you running on your procharged setup? 12+ psi
Old 02-27-2012, 08:21 AM
LS1RedZ's Avatar
Default What heads are you running on your procharged setup? 12+ psi
Just want to know what type of heads everyone is running. Im running TEA stage 2 LS6 heads and Im beginning to wonder if they are holding me back on some power. Anybody have any recommendations for heads that will perform really well on a high boost setup? Ive got a 370ci with a D1 right now at 9.1:1 compression. What are the limits of the LS6 casting before they start pushing water? (safe limit). Im only seeing about 12psi right now with a 3.4 pulley. Wonder if it will even be worth the swap.
Old 02-27-2012, 11:05 AM
brians91formula's Avatar
What are you making for power right now? A set of AFR or TEA 225 heads would flow better, make more power, and be stronger.
They are $2400+ brand new though.
Old 02-27-2012, 11:22 AM
eb02z06's Avatar
What size is the crank pulley? 3.4 on a Vette with a 8" crank and pump out 20 psi on a 347.
Old 02-27-2012, 11:33 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'm running PI (mast) 215 heads. With a 4.00" headunit pulley and a 7.65" crank pulley I was seeing 14psi at 6400rpm.
Old 02-27-2012, 11:58 AM
blue00ZZleeper's Avatar
I have stage 3 LS6 heads right now but plan on using some TFS-235cc heads soon.
Old 02-27-2012, 12:23 PM
eb02z06's Avatar
Is 7.65 as big as you can get on a F-body?
Why doesn't anyone make a 8"?
Old 02-27-2012, 12:29 PM
milkey57's Avatar
I have some ported prc ls6 heads here no complaints...thinkin about some afr's tho
Old 02-27-2012, 01:37 PM
eb02z06's Avatar
When you say holding back power-how much power?
For what it worth I've done several Patriot head deals at 900 rwhp and never pushed water.
Took off the Patriots and stepped up to some AFR 225's and made no difference either-blowers are cool that way.
Old 02-27-2012, 02:33 PM
UNDER PRESSURE MOD
As far as I know, 7.65" is the largest that's available. Not sure why noone makes anything larger.
Old 02-27-2012, 02:38 PM
eb02z06's Avatar
That's just nuts-on the F-body it's a 2pc setup right? You replace the dampner with a ATI unit and the pulley bolts up to it right? Or am I wrong?
Old 02-27-2012, 02:41 PM
UNDER PRESSURE MOD
That's correct. The 8-rib that you use with the Aster bracket is 7.65" but if you wanted to use the SDCE bracket, it's only 7.5" for some reason. I have to look, but it might have something to do with how the brackets are routed, I forget. I'm sure Bob can chime in and offer his expertise.
LS1RedZ's Avatar
Im making right at 700rwhp. It has made 754rwhp but im not sure how accurate the reading was. And for some reason the power is diving off well before 6000rpms.
Ive got the ATI super Damper which is 7.65 I believe.
14psi? What the hell. Are you stock cubes? See I should be seeing more than 11-12 with a 3.4 pulley.
I was thinking maybe around 50rwhp with a set of TFS 235s? I was thinking of maybe swapping heads for later on purposes when i possibly make around that amount of power. Plus the thicker deck would be nice too.
Old 02-27-2012, 02:42 PM
UNDER PRESSURE MOD
I am (was) stock cubes.
Old 02-27-2012, 05:14 PM
02LS1ram's Avatar
What blower bracket are you using? Could it be belt slip. What about
Valve float are your springs getting weak
Old 02-27-2012, 05:31 PM
UNDER PRESSURE MOD
Also, at that 14psi, I was maxing out 60lb injectors, so it's not like I wasn't making the power either or seeing 14psi of boost on a stock headed/cam/exhaust motor.
Gotta remember, boost is just a measure of the restriction of air that can't get into the cylinder head. So 14psi of boost on a 346 might only be 10psi of boost on a 383.
Old 02-27-2012, 05:44 PM
MikeFSKSpeed's Avatar
I've had great luck with AFRs for my boosted LS setups. If you need deals on AFR new, I'll hook members up!
Old 02-27-2012, 06:07 PM
allout06's Avatar
i made 5.5-6psi with a 7.65"/4.38". I plan on running Patriot 225's from ws6store. $1600. What CFM do your current heads flow?
Old 02-28-2012, 02:40 PM
LS1RedZ's Avatar
I shouldnt be having belt slip since I have Asters setup. Not sure on the valve springs. I bought the heads new and they MAYBE have 3000-4000 miles on them.
Yeah I understand the boost part, but i figure a 3.4 pulley should be making more than 11-12 psi.
Not sure exact numbers on flow, but i think maybe around 3-315 @ 600. They are the stage 2 LS6 from TEA.
Old 02-28-2012, 04:32 PM
allout06's Avatar
Well u are running a 370 with a set of heads and probably free flowing exhaust. So 12psi is pretty decent. I think its nuts that the alchemist was hitting 14psi with heads and only a 4.00 pulley i have stock heads and a 4.38" pulley and make 5.5 or so. I just can't see .38" difference make 9 more pst of boost....
Old 02-28-2012, 04:54 PM
UNDER PRESSURE MOD
What's your intake tract look like from the filter to the manifold?
I've got a monster of a filter on the truck intake hat, then 3" piping to a front mount intercooler, then 3" piping to a 90mm throttle body into the FAST 90mm manifold.
Quick Reply: What heads are you running on your procharged setup? 12+ psi
