Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
#321
compression in one cyl is 60psi cold closed throttle the rest are 130-150 soooo haha that one is hurt, i pulled the valve cover and thats ok, gunna be a piston or valve problem, im uploading a video quick, this plug was laid over onto the electrode, any reason why that happened, extreme heat?
itll be up then i have spare soldiers for this motor
#322
if i watch that video closely on full screen i can see it goes 10.0 afr then goes like 13.0 on spray in the beginning of the pass, nothing terrible. other than the meth isnt on till 10lbs, and i doubt it hurt the cyl then but it could have contributed.
it was smoking a tiny bit out of the valve cover when i checked it out in the pit so i knew i had hurt it.
#332
