Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 11-20-2012, 02:01 AM
  #1401
Turnin20s's Avatar
Originally Posted by adamantium
Whens it going back on the dyno?
He mentioned a couple posts up that by Friday it will hit the rollers.
Old 11-20-2012, 05:21 AM
  #1402
Moderator
denmah's Avatar
yeah friday we will have the sunbird and my fairmont on the dyno
Old 11-20-2012, 05:37 AM
  #1403
helga203's Avatar
Good morning, can't wait your one hell off a mechanic.
Old 11-20-2012, 08:47 AM
  #1404
gofastwclass's Avatar
i absolutely reused the connecting rod bolts.
Awesome, this just made my morning. Hahahaha!!!!
Old 11-20-2012, 10:30 PM
  #1405
mcspooley's Avatar
yep! he will b flogging the fairmont while im building my hotside friday. Man i hope the sloppyguys give out a trophy for longest distance traveld for dynodays next year. I'm already trying to find a way to get there. But by then none of the tracks in PA are gana let any of us sloppy approved cars and trucks run into the low 9's without any safety equiptment..... i got sent home for only having 1 throttle return spring last year
Old 11-20-2012, 10:38 PM
  #1406
86lxnotch's Avatar
matt and corey will be dyno flogging and ill be gunning for 8's....should be a great day
Old 11-21-2012, 11:37 AM
  #1407
mikesanto70's Avatar
got my gen4 **** today, wich you can see is so ****** beast like its awesome...
they look like aftermarket rods and pistons.
full floating wrist pin instead of a pressed, and the rod is a H beam style instead of a I beam hopefully much stronger, as i know people with gen4 **** making more power than me and not bending anything.
gapped all my rings to 28-30 so its ready for some abuse.
i plan to hit it with 30lbs if the ignition system will let me.
motors built, reused the ls1 head gaskets, and slammed it all in and bolted up the trans and connected a few things, and thats where i am quitting for the day, think i might do a compression check tomorrow as soon as i get the converter tight and put the starter in, to see what kinda compression its at now, since it has flat top 5.3 pistons in it now, gunna have more squish
This GEN 4 stuff here/pistons and rods, where/what motor did you source them from and are you putting these into your L33 block? If I understand it correctly thats what your doing!
Old 11-21-2012, 12:18 PM
  #1408
Moderator
denmah's Avatar
im not even sure really, i think they were out of an LH6? like a 08 and up 5.3
and yes i did install them and car is running great.
Old 11-21-2012, 09:27 PM
  #1409
mcspooley's Avatar
I sure thought the sunbird would b crazy loud inside but not bad at all will the exhaust off the tractor!!!!
Old 11-21-2012, 10:35 PM
  #1410
Moderator
denmah's Avatar
if you dump the exhaust out the front the cars are pretty quiet
running it under the car makes it drone in my opinion
Old 11-21-2012, 10:49 PM
  #1411
mcspooley's Avatar
when i had the big turbo on dmax i had 5 inch thru the hood and nos solenoid stuck lost a cyl and headgasket freaked me out had oil smoke and coolant blowing everywhere but she screamed at 62psi. i so understand the droan concern
Old 11-23-2012, 04:05 PM
  #1412
HRHohio's Avatar
OK Denmah... got a question for ya... which would you choose... (Using your builds as a model).
A) 2003 5.3 motor with 165,000 miles or
B) 2005 4.8 motor with 86,000 miles
Better Rods & lower miles vs. higher displacement... what would you do? (Same price...)
Old 11-23-2012, 04:26 PM
  #1413
gnx7's Avatar
The newer motor has better LS2 rods if you want to make more than 600rwhp....
Old 11-23-2012, 07:10 PM
  #1414
Twin turbo c5's Avatar
I agree I've had 2 other turbo cars with just a dp in front of the wheels works great and no drone.
Old 11-23-2012, 09:12 PM
  #1415
mcspooley's Avatar
I sure am crazy anxious to hear how matt and corey did on the dyno...... Anyone hear if they even made it to the rolers today
Old 11-23-2012, 11:45 PM
  #1416
Moderator
denmah's Avatar
I did 640 on 20 lbs picked up 40 rwhp actually and the I topped out my boost controller and it hit 26.8 and I think I lifted a head lol, and the sunbird has a miss and made 350rwhp lol not a good day unfortunately
Old 11-24-2012, 12:18 AM
  #1417
alexcoreas's Avatar
You lifted with ARP head studs?
Old 11-24-2012, 12:37 AM
  #1418
ronnieforrester's Avatar
lifted a head from too much boost and/or timing ? thast sucks- sorry to hear bro
Old 11-24-2012, 12:57 AM
  #1419
skinnies's Avatar
Surprised it lifted, especially on the dyno.
Old 11-24-2012, 01:42 AM
  #1420
Moderator
denmah's Avatar
I drove home and it still has 20 inches of vac at idle. I'm gunna do a compression check on it soon not sure what happened but it got upset on high boost and I left out lol maybe I'm blowing out spark again. Not sure. I don't think I like these br7ef plugs think ill go back to tr6
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
