Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 11-24-2012, 03:08 PM
  #1441
atomic 6's Avatar
Originally Posted by mcspooley
Ok i do understand hardparts fail and that sucks even good expensive parts but matt your batch firing the injectors and waste firing the plugs on the microquirt is it possible your having an ignition event in #7 since 7 is allways the hottest cylinder? Hell ive even seen the old Grand Nationals light off a cyl just from pressure...
So you think the BANK fire injection, or the wasted spark contributed to a preignition event.
I have never seen either of those contribute or cause a preignition event, and having Grand Nationals and tuning Turbo Regals since 1996 I have never heard of the TRs Preignite on E85 or gas/race fuel. Unless there is oil in the combustion chamber somehow, or too hot of a plug.
Although, E85, and Especially Methanol, will go straight to preignition, skipping the detonation, altogether. But that is usually because of too hot of a plug, or too lean on the fuel. Or like I said oil in the chamber.
Also,I was wondering if you would have problems with keeping gaskets in that engine, after torching that head that bad. The block had to have had some damage to the deck. Did it get decked before the new head and gasket were installed? With my old Supra, once you blew a head gasket there was alot of work to get that surface right for another metal gasket to seal correctly.
Old 11-24-2012, 04:33 PM
  #1442
Moderator
denmah's Avatar
the other side of the motor, cyl6 is where i burned the gasket out.
Old 11-24-2012, 04:37 PM
  #1443
skinnies's Avatar
You know my opinion, ditch the nitrous/meth, build it right once with a 7675 and don't look back.
Old 11-24-2012, 10:33 PM
  #1444
mcspooley's Avatar
Whats Skinnies talking about "7675"?????
Old 11-24-2012, 10:36 PM
  #1445
86lxnotch's Avatar
turbo
Old 11-24-2012, 11:10 PM
  #1446
Moderator
denmah's Avatar
i think ill spend money on a intercooler and a intake and buy a turbo from craigs guy similar to those pte 7675s
Old 11-24-2012, 11:23 PM
  #1447
mcspooley's Avatar
I must be missing it? What is a different turbo gana do for you matt? More boost but isnt that the problem to begin with?
Old 11-25-2012, 07:21 AM
  #1448
Tjabo's Avatar
Are you concerned that the high IATs from running without an intercooler might be causing you detonation problems even with the e85 and meth?
When I was running really high volumes of 70% meth (injected after the intercooler), I was concerned that the distribution might be far less than ideal given that we are using intakes designed for N/A dry flow... Still, the meth was tolerant of a rather rich mixture, and nothing bad seemed to come of it. I figured that if the distribution was sufficiently bad to cause a problem that the plugs and/or combustion chamber should show evidence of it.
What intake are you thinking of trying?
Old 11-25-2012, 07:25 AM
  #1449
a4ls2goat's Avatar
Imo throw the intercooler back on. Atleast the big eBay one. I'm running the 31x12x4 with out issues.
Get rid of the meth, you don't need that **** with e85. Lol
Old 11-25-2012, 07:30 AM
  #1450
86lxnotch's Avatar
i think he should go back to a meth/water mix. the water cools better than the meth but the meth gives octane. imo with the e85 the octane is fine.
Old 11-25-2012, 08:05 AM
  #1451
Tjabo's Avatar
I think it's accurate to say that the methanol cools the IATs better than the water through evaporative cooling because the methanol evaporates more readily upon injection into the heat of the intake tract. Water on the other hand, cools the actual combustion chamber temps better than the methanol because of its higher specific heat. I too think that a blend probably has the best effect, but I never did try the straight methanol and a lot of people swear by it.
Old 11-25-2012, 09:47 AM
  #1452
Camaro9969's Avatar
Exactly E85 is perfect on its own no need for meth.
Old 11-25-2012, 12:49 PM
  #1453
driver56's Avatar
From an engine builders point of view, I'd quit throwing used head gaskets on the thing and use new gaskets that are designed for boost. And there's nothing wrong with using ARP bolts or studs a million times unless they're overtorqued and stretched. You have to use the right lube (ARP Ultra, in the blue packaging) and follow the manufacturers directions, not what some Joe said to do on the internet.
Bad *** car though, love that the big money guys hate it and say you can't do that.
Old 11-25-2012, 01:54 PM
  #1454
YungSteph's Avatar
I just read this whole thread front to back over the last 2 days and I just realized all this was in under a year WOW!! I'm a big fan of your work. Come January I'm starting my build in search of 550rwhp. I'll be in boxing you. Keep up the great work
Old 11-25-2012, 03:59 PM
  #1455
adamantium's Avatar
Yup! Ive always though about meth with e85 but never seen anyone attempt it, i would how much lower the IAT's are with this setup.
Old 11-25-2012, 04:32 PM
  #1456
Sarg's Avatar
Well or just spray a little of the E85 in the inlet charge....would probably serve about the same purpose. I have thought about just adding a little stock injector somewhere in the inlet/intake that opens with a hobs switch.
Old 11-25-2012, 05:02 PM
  #1457
86lxnotch's Avatar
sarg i thought about something like that as well. i was going to use a nitrous/fuel soleniod operated on a hobbs switch. plenty of jet sizes to choose from too!
Old 11-25-2012, 05:14 PM
  #1458
Sarg's Avatar
Would be super easy, just no water as an option, lol.
Old 11-25-2012, 05:36 PM
  #1459
skinnies's Avatar
Allow him to make the power the car should on the boost numbers. No reason it can't make over 800rwhp on a 7675, the magnum 80 doesn't seem to be cutting it. I gave other suggestions on what to do, I like to drive my car though and be simple vs working on it and tearing it down all the time.
Old 11-25-2012, 05:42 PM
  #1460
mcspooley's Avatar
Skinnies! hey brother you talking about turbonetics turbo? whats really the diff between them? this is actually a smaller turbo then matts mag 80
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
