Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 01-02-2013, 04:23 PM
  #1681
Tjabo's Avatar
Ok, I hear you on that.
Old 01-02-2013, 05:03 PM
  #1682
Moderator
denmah's Avatar
I agree I really really like my plug and play switchable tune lockup etc etc 80e controller
Old 01-02-2013, 05:40 PM
  #1683
Sarg's Avatar
Which one do you have denmah?
Old 01-02-2013, 06:12 PM
  #1684
Moderator
denmah's Avatar
http://www.usshift.com/
Old 01-02-2013, 06:36 PM
  #1685
Tjabo's Avatar
That's a slick unit. Is the sale still on where you can get the controller and a harness for $515? Too bad I'm not ready yet... Maybe I'd go that way even though I'm a devoted MS'er.
Old 01-02-2013, 06:58 PM
  #1686
atomic 6's Avatar
Originally Posted by Sarg
Just the tcu, but if you are going to pay $350 for a second microquirt, it is not much of a jump to get the Fast TCU that comes with a harness and is basically plug and play.
Yes, but when you have a Micro controlling the transmission also, you can get boost by gear, or boost by speed, or boost/nos from launch, because the transmission controller is now sending that information to the Fuel/Spark ecm that is controlling boost. Then, the next step is if you get an AIM dash all of that stuff can be displayed from the can bus wiring, Speed, Boost, MPH, RPM, AFR, or almost anything the squirt monitors.
The can bus stuff is prety cool, and very powerful.
So, it costs less, and besides getting transmission control there is extra stuff you can only get when running a Microsquirt on the transmission, and a Megasquirt variant on the engine(MS2,MS3,Microsquirt,MS3pro)
My Twin turbo nova has been running a Microsquirt on the transmission for over 3 years now.
Old 01-03-2013, 05:50 PM
  #1687
Sarg's Avatar
That is really cool! Boost by gear would be very nice. You are pretty much limited to an aftermarket controller for that or a high end ecu. Nice to know micro could do it. Is the programming already developed for that with micro squirt or is it something that someone would have to figure out/write?
Old 01-03-2013, 08:31 PM
  #1688
TurboMonte100's Avatar
Matt I checked out some of your videos on utube, They are helpful and entertaining. I like the one showing the rings and the broken pistons, It shows what I have been telling guys about ring gaps. Now I do have one question.
Dude..... are you running around that garage without any damn shoes on??? Lol
Old 01-03-2013, 10:20 PM
  #1689
Moderator
denmah's Avatar
Old 01-04-2013, 09:20 AM
  #1690
Tjabo's Avatar
Been out driving/tuning yet with the new cam, denmah?
Old 01-04-2013, 12:36 PM
  #1691
Moderator
denmah's Avatar
nope i havent done anything but start it that day, been busy haha, put 80lb injectors in that firebird last night and had it out for a bit, gotta get that, the turbo lsx gremlin, and the twin turbo 5.3 camaro, and my turd on the dyno sometime soon
Old 01-04-2013, 08:40 PM
  #1692
BIGHAL's Avatar
Denmah I have a Mercury Zephyr Wagon. I bought a 91 GT 8.8 3.73 gear Posi rear end. Will it fit right in? What gear ya running? Forgive me . I didn't read 85 Pages lol
Should I get a 5.3 or 6.0? Does the truck Alt/PS brackets work? Did you use the truck oil pan? 4Lug Wheels?
Old 01-04-2013, 09:53 PM
  #1693
Moderator
denmah's Avatar
i replied to your pm, but yes, 8.8 out of a mustang will bolt right in
throw 28spline alloy usa axles in it from summit for like 220-250 dollars
im running a 3.55 now, i used to have a 2.73
i would get whatever motor is cost effective, since you can make basically the same power with them all.
truck alt bracket will not fit under the hood, you can get a C5 corvette alt bracket and power steering pump and space them out a little bit to fit the truck water pump and tensioner and then you are good.
Old 01-04-2013, 10:24 PM
  #1694
mcspooley's Avatar
Denmah, plent of room in the caprice for 2 or even 4 turbos lol had a 70 with 402 big block Chevy th400 4500 stall 12 bolt with 538 gears and old as cummins diesel turbo with bs blow thru carb was Crazy fast but ran out of motor at 118mph
Old 01-05-2013, 02:46 AM
  #1695
Checkmate's Avatar
x2 that caprice is sweet, plans for it?
Old 01-05-2013, 09:06 PM
  #1696
Moderator
denmah's Avatar
i scrapped it this morning
Old 01-06-2013, 10:32 PM
  #1697
Moderator
denmah's Avatar
i have the car out with the new cam and retuning on pumpgas instead of e85, im on 11psi about right now.
seems to work pretty good, we will see what the dyno says then.
the footbrake into the anti lag is amazing, ill get a video of that,
i can foot brake it into the anti lag and it will sit still and not push at all and make 8psi of boost, car should leave like an animal
i have the settings really nice so it doesnt pop or beat up the turbo at all, it just sits and stutters at 2700 and 8psi lol
Old 01-07-2013, 02:25 PM
  #1698
Sales@Tick's Avatar
So can you say for 100% sure that it's stronger with the new cam and builds boost quicker than the LS9 cam?
Old 01-07-2013, 02:39 PM
  #1699
Moderator
denmah's Avatar
it does seem more lively than the ls9, can you explain that, is it the LSA helping?
it is running less boost, 11psi vs the 15 or so i would hit with the LS9 cam...
is that the longer intake duration or the shorter LSA affecting that, nothing else has changed with the setup.
ill have it on the dyno soon, this car would do 600whp on 20lbs pretty regularly before. cant remember what it did on 10 and 15lbs been a while i think low 500s on 15psi
Old 01-07-2013, 02:42 PM
  #1700
Moderator
denmah's Avatar
also i have a corvette power steering pump from a friend, and i just bought maximum motorsports fittings that convert the rack to AN fittings, gunna try and put power steering back on this pig haha that will really make it a cruiser
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
