Rumor on cometic gaskets.
Are there any other gaskets that I could run untill they get this straightend out? I want to try and return the ones i have for the new updated ones that won`t leak water and I`m not gonna wait to get the new updated gaskets before I do my heads, cause i`m sure it will be awhile before they get it straightend out. So what are your opinions Fel pro or the stock 6.0 gaskets? I`ve heard that the 98-00 cars use differant gaskets then the 01-02 car does the same go for the 6.0 heads? Is the differance in the heads or the block? Thanks guys.
The f-body started using the mls gaskets in 2002. I would check to see if your heads have notches in them before I used the mls gaskets.
Clint
Just my 2 cents.
Clint
They had alot of problems so i thought they axed them.
the regular MSL should be fine, thats what i have been using and reusing.
It is good insurance to use copper spray. I used it on my cometics with no problems for 2 years. I spary my car with a considerable amount at times. Lingenfilter uses copper spray on all their twin vets. JFYI
Last time I asked Cometic about the rumour they denied any problems.
Assembling an HP MLS motor right now.
Will give them a call tomorrow.
