Yay! My Kando turbo for APS kit is blown!
So after roughly 100 miles of street driving, and then about 4 pulls on the dyno @ only 9 psi, I went out to start my car and take it around for a little, and the drivers side turbo is smoking like a ***** F#%$er.
So I guess I have just proven to everyone else that these center housings from Kando Dynamic, which they claim are of the "highest quality" are no better than the stock pieces of crap that APS gives you.
Now I am really at ends on what to do with this car... I really wish I could go to a PT88 front mount right about now.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Now I am really at ends on what to do with this car... I really wish I could go to a PT88 front mount right about now.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
This is the center section:
So, the compressor and turbine wheels are that of Kando's.
Basically everything is a Kando CHRA except the hot and cold side castings, which are just that. Cast metal.
You are still trying to push 10 lbs of **** through a 5 lb bag. Your motor is too big, and your turbos are too small.
Any idea on backpressure? Any idea if you are over-spinning?
PSI doesn't matter. You need properly sized turbochargers. <- That was a period.
Thanks dooood!
I hear you on this, but I still think on how much I have run them, it was still WAY premature. If they had failed after I had been running 20+ psi for 4 years, I don't think I would be as mad. lol
Thanks man, again I hear that. I am just really getting tired of putting money in to this kit and not getting results. I can definetly understand why TomZ28 switched now. haha
I seriously think it is that you are fine, and I am just extremely UNLUCKY! lol
Originally Posted by Toxic-evo
Sorry. But wade is right. Starting with DKT turbos having a 1.06 a/r and a 62 or 66 mm exhaust wheel will really help with back pressure.
Originally Posted by KnightmareLS1
Have had my Kandos on my stock cube motor for thousands of miles no probs. Maybe Im just lucky...
Thanks man, again I hear that. I am just really getting tired of putting money in to this kit and not getting results...l
So stop spending money on BS and start spending it on something that will truly fix the problem.
-W
