Turbo vs Prochrager
M6 2000 Firehawk
402 iron block ( everything ARP studded and bolted)
eagle crank
eagle H rods
Diamond nitrous dome pistons made into flat tops with "D" shape 10cc dish w/ valve reliefs
243 heads (studded)
Fast 90
247/253 .620 .638 116LSA cam
No penny spared on any part, not a single one
I also have a stand alone fuel cell to use
I'm looking for some options/opinions.... Obviously I'm going for some big #'s..lol. This is a street driven car
For me what it really came down too was money. For the price for a D1SC or an F1A Procharger setup I was going to be over twice as much as what I was able to built my turbo setup for. I was unable to find any decent priced used Procharger setups when I was searching but if I had for a decent price I would have absolutely went that route just because of the simplicity and no BS that a Procharger will give you. A turbo setup requires more work, fabrication, and effort IMO but the results can be whatever you wish as long as you plan things out ahead
Procharger will be louder, since its cramming in all of that air with no exhaust restriction. Turbo will be quieter, since they act as an exhaust restriction and can quiet down a car quite a bit. The turbo is capable of delivering more torque, as long as you size the turbo(s) correctly so that they start to spool early. Turbos can hit max boost very quickly and hold it, while belt-driven systems must build this boost with RPM.
From experience, turbo cars are often quieter and more tame on the street. It mostly comes down to preference if you aren't worried about the budget.
i guess i would say matching the turbo to the engine is much more important for quick spool with a manual then it is with an auto. Im sure with an auto and a nice converter you can get away with a much bigger exhaust housing for great top end power and still quick spool.
Turbo setups are more complex in the piping but a lot quieter than a supercharger.
My good friend was a supercharger guy with some big numbers. He's had his challenges with belts breaking, supercharger failing and having to come up with custom pulleys to increase HP because the track could take it.
Me, I've had no issues and if the track can take it I hit the up button on my programmable boost controller and set a new boost target.
Get a price on a custom kit for your car to meet your needs from a speed shop. Then take that parts list and think about building it yourself. It should give you a good idea of how much you're going to spend.
