Turbo converter..anyone pick up mph going to a tighter converter?
I shift at 6000rpm, my peak torque is probably 4000-4500. My converter couples at 5300 minimum and the shift from 2-3 the rpm only fell to 5700. The car sounds like a snowmobile going down track. Im hoping going to a much tighter converter will pick up more mph or else Im not making much power for my combo. Has anyone seen their car pick up mph with a tighter converter?
wow your are running a ton of gear.
and not spinning it very high which would help with coupling
what does it run? i am very curious because i just about stuck 2.73s in my car but was scared too. haha
i have a similar setup but with a glide and 3.08s, i shift at 6700 and on the transition will drop to 5500-5600. also when i come hard into boost no matter rolling or stopped it will flash to around 5500 and go from there
I only have two time slips on it, first at 7# was 6.9@107, the second only got one pass that day and was 6.6@110 at 7.5#. 60' was 1.7 and 1.6 respectively. First pass I wasnt full throttle until half way. But I figured it would be alot closer to 115mph on 7# as light as the car is. The 2.41 gear and th350 (1st and 2nd) make it about the equivalent of running a powerglide and 3.73 gear.
My 60' are terrible so far, I have to work on that, but I feel like Im either not making the power I should be or the converter is the problem with my mph. Im putting a tighter converter in now, just wondering what others have seen in this situation.
Thanks
Thanks
Thanks
Thanks
Thats whats in it, JD Hyguard, thanks for the idea.
I think about 2600# with me in it, not 100% sure.
Yes foot braking. It stalls right around 3000, but will climb up to 4000 after a few seconds, brakes barely hold it there.
Did you have the same type of loose converter at first and went to a tighter one?
Thanks
Thanks
LS1Tech Co-Founder
I only have two time slips on it, first at 7# was 6.9@107, the second only got one pass that day and was 6.6@110 at 7.5#. 60' was 1.7 and 1.6 respectively. First pass I wasn't full throttle until half way. But I figured it would be a lot closer to 115mph on 7# as light as the car is. The 2.41 gear and th350 (1st and 2nd) make it about the equivalent of running a power glide and 3.73 gear.
And I'd be trying in those 7-8 full passes a few different shift points.... 5800, then 6100, 6300, 6500... 6700... Or has it been dynoed? What intake?
Maybe you are leaving info out, but why would you change the converter before getting a couple of good hits out of it? I wouldn't change a single thing until I had like 7-8 full good passes out of the current combo. What will the rpms go up to on the 'brake without a 2 step engaged?
i dunno man i wouldnt get too crazy about changing right away
my converter acts the same as yours
if i am going down the road in high gear at 2000rpm and go WOT it will flash to the exact same area as yours (5.3-5.5k) as boost comes which is almost instantly
yet it still drives around nice and tight putt putt and cruising down the highway, on the transbrake i can come to however much boost i want withing 2 seconds
at the track it is right in the 6% slip area as it crosses the line (1/4)
mph seems alright for stock heads at that boost for a little turbine, what turbine are you actually using
have you figured your rough slip? how high of rpm do you cross the line at, and what mph and tire height?
yeah that it quite a bit
spinning it higher should couple it better but i wouldnt think that much
are you running a 10" converter? i am running a 10" ptc
i wasnt sure if you were running an older small turbine or the gts, that should be right happy
LS1Tech Co-Founder
Is it a 8" or 9" converter? Sounds pretty loose for your combo. PTC was really good with Andy (moderator lastls1) when he had his tightened, maybe ask Lane over at PTC what he could do for you.
It is a 10". PTC is great, I dealt with Tim, they are really nice to deal with, they swapped it out for a tighter converter more toward being tighter on the freeway. I think if I was wanting max ET(like 99% of their customers), running more gear and more rpm this converter would be perfect, its just kind of a bizarre setup compared to others I think and I didnt realize it when I ordered the converter.
let us know how it works out!
have any pics of the ride?
i do like the idea of the deep gearing with a 3 speed and effectively having an PG with OD
but i already had the pg when i pondered such a thing
hope it works out, will be a sweet street/strip combo
