F1r procharger on high compression motor
Wassup guys im looking for a bit of insight here my current dilema is that i have some tfs 215's that were milled 0.10 and i also have the tsp tsunami cam so i'm just guestamating that my cr is around 11:1ish. I want to run a cog setup with this and i was wondering what would be a safe boost level to run on the sbe until i'm able to forge the motor.
Depends on how you want to do your fuel system and if you want to be on the high end on the F1-R's power making capabilities. I personally don't think 1100 rwhp is not out of the question with that compression ratio and some good octane.
I think some 100lb+ injectors, or some 1000cc, would be enough. Get an adjustable fuel regulator. Base pressure plays a big role on what type of fuel system setup you can go with. Three 255 pumps or two and a nice inline pump can suffice. basically there are a lot of options. Most people tend to use 93, that requires a lot less fuel. I'll let the fueling experts correct me if I'm wrong on my advice.
I'm gonna link this to my thread..
Good info here. I have a forged 403ci LS2 motor in a built 2002 Camaro. But i have 12.3-1 compression with the same heads. My heads a little work done to them. We opened the port up to a 4" and dropped in bigger intake valves. from a 2.040 to a 2.055 intake valve. Heads were milled to 63cc but them we opened the bore on them. I'm not sure of any places around here that sell E85..
Im confused Ur telling him he can make 1000+ I thought he said his motor wasnt even forged?
No, I'm telling that his blower can support 1100rwhp and to build his fuel system so it can be ready for the forged engine. There is no reason to buy the fuel system twice. The base fuel pressure makes a sizable difference on the limits of the injectors. The lower it is, the lower the limit that they can support. Blackonblack what was your pressure set at? You could be correct in him needing the 2000cc's.
93 octane would support 11.1cr on low boost with a dedicated water/meth set up right. By low I mean 8lb or less on a daily driver. For race day you'd want higher octane to wind the wick up and forged pistons. The combustion pressure on that cr at higher boost will blow the ring lands on stock pistons.
You can run 12-14lbs of boost with 11-1 , 93 and methenol. We do that alot on stock motors but there is more too it like DCR ect.
With a F1R it will be doggy. You'll need a 5.5" wheel to keep boost down which probly won't fit.
Spend the money on a new motor first since thats part of your plan.
