One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
Old 06-10-2013, 04:41 PM
  #161
TDMKR496's Avatar
Are you using a stock ECM or something like MS?
Old 06-11-2013, 12:50 PM
  #162
LS1NOVA's Avatar
Its stock ecm and HPtuners. Carl at CJtunes here in St Paul does the tuning.
Here is the uneventfull video from the 942 pull. Through the 3.5" single exhaust.
Old 06-11-2013, 01:34 PM
  #163
BanditDave's Avatar
Nice uneventful ~1000 whp pull...no biggie...haha
Old 06-11-2013, 03:03 PM
  #164
boss79z's Avatar
Very nice car and build!
Old 06-11-2013, 04:18 PM
  #165
DavidPHumes's Avatar
Beast mode
Old 06-11-2013, 04:48 PM
  #166
RonSSNova's Avatar
That's quite a nice facility.
I think it's going to be a handfull at the track. Hope it sticks in high gear!
Ron
Old 06-11-2013, 11:06 PM
  #167
94 slow's Avatar
All that through a 4L80. Good job!
Old 06-17-2013, 06:37 PM
  #168
RonSSNova's Avatar
Originally Posted by LS1NOVA
Well got the new setup to the dyno. Ended up with 942whp at 27lbs. I was willing to do whatever it took to hit 1000 but maxed the 120 injectors on 43psi base, we turned it up to 50 and then went a little lean as the two Bosch 044 (one on a bap) were done. Time to add another pump. No street time yet. Track times next weekend in Ia!
Did you get to the track? "Next Weekend" has come and gone!
Ron
Old 06-17-2013, 10:08 PM
  #169
BanditDave's Avatar
Ron
What he said...
Old 06-17-2013, 10:39 PM
  #170
Slow94Formula's Avatar
He didn't go to the track. The weather forecast looked like rain. Still waiting for a reschedule date myself!
Old 06-18-2013, 05:21 AM
  #171
LS1NOVA's Avatar
Yep didnt go. Damn longest winter ever has rolled into wettest spring ever. I'll probably put it back on the dyno with another fuel pump before its convienent to take it to the track.
Old 06-18-2013, 08:18 AM
  #172
Chicago TDP's Avatar
You are killing me....I am going to have to ditch my PTE7675 now and go 88 cause of you.....dangling this kind of power in front of me is dangerous!
Old 06-18-2013, 12:47 PM
  #173
LS1NOVA's Avatar
There is no reason the 76 cant make the same power, just have to put your big boy pants on and crank it up!!! The 76 definately spooled better but I dont have the tune nailed down on this one quite yet so its still up in the air a little. 1000whp to come though..
Old 06-24-2013, 06:53 PM
  #174
cam
cam's Avatar
Pretty badass. In for track vids
Old 06-25-2013, 03:54 PM
  #175
00duvall's Avatar
Im in for more videosU give me motivation.[IMG][/IMG]
Old 06-27-2013, 12:43 PM
  #176
94 slow's Avatar
Nate,
How high are you spinning this motor? 7k rpm?
Old 07-27-2013, 08:44 AM
  #177
RonSSNova's Avatar
Any track outings yet with the new turbo?
Ron
Old 07-27-2013, 10:57 AM
  #178
LS1NOVA's Avatar
Going to the track Aug 9th.
Old 08-08-2013, 07:43 AM
  #179
Forcefed86's Avatar
Great build!
Have you ever checked your back pressure? Curious what you see with the 2.25” pipe. I was thinking of necking down my 2.5” setup this winter for quicker spool. Just threw on a cheapo oil pressure gauge and I’m seeing around 1.3:1 at 17lbs with an 83 wheel and a 1.10 AR T4.
Also…Did that piston rod combo just drop in the factory bore? No machine work required? What did that piston/rod setup cost roughly?
Thanks!
Old 08-09-2013, 05:31 AM
  #180
LS1NOVA's Avatar
Wiseco pistons and Eagle rods for just under $1000. Using an .020 overbore.
Quick Reply: One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
