Dropping compression from 10:1 to 9:1 require a larger turbo?
If I drop my compression a point will it reduce that 800rwhp level of my current turbo? If so by how much. I'd assume that it would take more air to fill the larger combustion area, but in the grand scheme of things it is only 11cc per cylinder of extra volume.
Any input here?
That turbo makes 21-23psi on two forged 370's here locally. Both have a good set of aftermarket/worked over cylinder heads. They trap 129-132mph. One weighs 3420ish and has trapped 129 in the 1/8th and 161 in the quarter while the other at 3250 has been 132 in the 1/8th.
I'd say you have some room left to turn the wick up on that turbo you have now, but now would be a good time to go ahead and upgrade.
You can send the turbo in and have the compressor side upgraded to a billet wheel 76mm wheel that the new S476R's are using, you can upgrade it to a 80mm wheel, 82mm, 83mm or you can ditch the S400 chassis altogether and step up to a S500 series turbo with the 111mm turbine versus the 96mm turbine. You will most likely either need to advance the ICL of the cam you have now and possibly a new grind, but advancing it first would be what I would do.
There is also a S488 out there that uses a 108mm turbine wheel and a 88mm compressor wheel. Bullseye power makes one with a 1.0, 1.10 and 1.32 AR housings. I would use the 1.10 or 1.32.
Not to nitpick, but from my understanding VE should stay the same. It cuts peak compression/peak cylinder temperature so the whole process is a smidge less efficient.
I think you'll spool a little slower as well - just something to keep in mind when you get your other turbo.
Any input here?
You need to establish if the turbo is the problem or not. You know boost pressure, but what is turbine pressure like ?
What is your tuning like ? What fuel are you using ? What are intake temps like ?
If your fuel was a limitation, then a lower CR would allow running more timing for any given boost which could help power.
There are alot of variables here though. Especially, if you are on pump gas at the boost level you listed. You may find that the lower compression will allow you to advance your timing to a more optimal point....in which case, you wouldn't be down any power.
I'm also a fan of specing the pistons to achieve a healthy amount of rise to minimize the squish - seems to help in building a detonation resistant motor. I don't know what the trend is now days, but I know a lot of shops used to build a zero rise or even deck piston motor.
Also on the list of gizmo's that help alot with detonation is your intercooler - if you haven't looked at it already.
Methanol works great, I'm just leery of pushing people towards it because I've seen a couple motors give up the ghost as the result of a methanol system failure.
