Maggie 112, valve float or out of blower ?
.back pressure from exhaust
.blower cavitation ( out of blower,, lol)
.belt slip
We ruled out exhaust by opening just after y pipe, no difference other than 20 HP gain. I have been driving daily for about a month now. According to my boost meter, I'm gradually losing boost after 5k rpm. Running 7lbs (2.9" pulley)
It drops gradually down to about 2 lbs between 5,000 to 6,200. still pulls hard all the way. If it helps my numbers were as follows:
(stingy) Mustang Dyno on a hot so. Fl day 470rwhp /515trq.
W/ 50 shot n2o ( intended to cool IATs). 515rwhp/570trq.
Still had same flat spot @ 5,800. I did put a manual tensioner on to eliminate belt slip. It helps a little. But still bleeds boost off. I am now thinking valve float can be the issue.
Now: I am ok with this issue if I am just out of blower. I know my set up is only good for about 500hp or so ... I'm there. However, if it could be some other issue I don't want to leave the ponies & my beloved torque on the table.
All mods in sig, the springs we used were a kit that came from comp cams along with the cam. I am embarrassed to say that I don't remember which springs we used. I have about 7,000 miles on the new build. Part of the problem is that I do not have an original Dyno to use as a benchmark to check against lost boost drop etc.. All of this came to light after the slipping clutch was replaced.
Thanks in advance for any insight.
Weren't the 112's orignially used on the 3.8l v-6 motors?
Alchemist: thanks for the description.
You can get 500+ WHP with a 112 on a LS2 with stock cam, stock heads, shortys into factory cats. Takes a 2.6 pulley but plenty have gotten those numbers. Even my A4 puts down 480 WHP with a 2.7 pulley. Add a blower cam and 550+ WHP is easy.
Noticed you are on a Mustang dyno too. 470 isnt too bad although mine ran a hair under 450 on a Mustang Dyno. You really should look into getting a 2.7 pulley atleast. It will REALLY wake that car up ! Another 2-3 PSI and you will be seeing another 40+ WHP. Oh and get a ECS tensioner with a Gatorback belt. Will get rid of slip down to a 2.6 pulley.
Even in the case you could spin that 112 fast enough to make that kind of power, it would create so much heat the ECM would yank a ton of timing because of the IATs.
My S10 with a 5.3l on E85 with a 224 cam did 500 through a 80e and a 3" pulley. I figured it might have hit 530 with a 2.6 or 2.7. Again that is on E85 with 24 degrees advance.
Put down 541.66 rw hp 473.xx rw tq on dynojet on 9.22 psi.
Car is in the shop for (yet again) another clutch issue. We have adjusted for WOT and plan to recheck the tune etc..
My question is now:
Could the lack of air be the cause of my boost drop. At 82% open on my NW 96mm its as if I'm running a 78mm TB. Now I know my blower is limited ... But can anyone address this as a possible cause ?
New Dyno results coming this week.
RECORDS (based on stock-cube LS1)
MP112 Horsepower Leader: ddawson @ 560 A4 trans
MP112 Torque Monster: ddawson @ 536
RECORDS (based on stock-cube LS2)
MP112 Horsepower Leader: CHA-LEE @ 590
MP112 Torque Monster: Willow @ 561
82% won't hurt much. It's close to being in the shadow of the blade at that point. Not that much of an issue as one thinks.
Just writing down a bunch of numbers doesn't prove anything.
Here:
Record D1SC procharger, stock cube ls1 : The Alchemist @ 965 T56 trans.
