Compressor wheel rubs inside of housing
Old Jul 23, 2012 | 06:10 PM
Ferocity02's Avatar
Default Compressor wheel rubs inside of housing
I bought a used MP70 from a member on here and he claimed it has low mileage but it was pretty dirty and the compressor blades were slightly chipped like it was run without a filter. It showed up with the compressor housing bolts snugged but not tight. One of the three brackets was bent.
Anyways, I took it apart, coated the turbine housing, and painted the compressor housing. While it was apart all I did was put some oil down the oil feed hole to keep it lubed. It sat on a shelf for a couple weeks till today when I put it together. With the compressor housing bolts snug, it rotates fine. Then when I tighten them to no more than about ~8 ft-lbs, the compressor blades rub in the inside of the housing. Turbine is fine. The shaft has 0.01" radial play measured with a dial indicator.
Did I buy a crap turbo or am I somehow assembling this thing incorrectly? Thanks!
I marked the blades with black sharpie to see where they were rubbing. You can see they are rubbing on the very corners. 10 of the 12 blades show rubbing.
Old Jul 23, 2012 | 08:17 PM
montanatrout's Avatar
looks to me like the housing "halves" are not seated. if it was the bearings in the turbo wouldnt you get rubbing all the way around?
Old Jul 24, 2012 | 11:18 AM
Ferocity02's Avatar
It's impossible to not seat them together correctly, unless I'm totally missing something.
Anyone else?
Old Jul 24, 2012 | 11:56 AM
KILLER-LS1's Avatar
Axial play is more important to check. (movement in and out). With radial play, the wheel centers itself (assuming its balanced) due to centrifugal force. Clamp the turbo in a vice and put your dial indicator on the end of the compressor shaft, and grab the turbine side and push it in and out.
Old Jul 24, 2012 | 12:40 PM
Ferocity02's Avatar
The axial play is minimal, 0.001 if that.
Old Jul 24, 2012 | 12:50 PM
96s-10ss's Avatar
Then I would say you got a good turbo. Just something is different when youre putting it back together. Do you have the oring in the compressor
housing?
Old Jul 24, 2012 | 12:55 PM
Ferocity02's Avatar
housing?
Yup, o-ring is in there. Is it possible to take it apart to inspect the bearings? I see the nut on the compressor side of the shaft, but is the compressor wheel pressed onto the shaft?
Would there be any issue with filing down the corners of the compressor a tiny amount so it doesn't rub?
Old Jul 24, 2012 | 01:06 PM
KILLER-LS1's Avatar
I wouldnt take it apart. Its like removing a tire from a rim, it needs to be balanced. you could mark it, but i wouldn't risk it with a wheel spinning 100,000 RPM
I see silicone on some of the bolt holes. Did you do that? There is a chance the housing could be warped from someone over torqueing it. I would clean off all the silicone, and use a straight edge & feeler guage to see if there is any warpage.
Old Jul 24, 2012 | 01:20 PM
Ferocity02's Avatar
I did not do the silicon. It looks like that was to help seal those two bolt holes since they protrude into the compressor housing.
Old Jul 24, 2012 | 01:42 PM
Ferocity02's Avatar
Whats the torque spec on the compressor housing bolts?
Old Jul 24, 2012 | 02:38 PM
KILLER-LS1's Avatar
Dont know the spec, youd have to call the manufacturer.
It doesnt really matter as long as they are all the same. Id try 10 ft/lbs and see how that feels. Do it in a star pattern to evenly seat the housing
Old Jul 24, 2012 | 03:42 PM
Ferocity02's Avatar
I think I figured it out. Took a straight edge to the compressor housing backplate and it's definitely warped. The first two pics are of one side that's flat, and the other three pics are of the other side that's warped. This makes sense, the way its warped it will bring the compressor housing closer to the wheel causing it to rub.
Flat side:
Warped side, see gap under right side of straight edge:
Old Jul 24, 2012 | 04:32 PM
96s-10ss's Avatar
That sucks. Maybe get ahold of masterpower and see if you can get a new backplate.
Old Jul 24, 2012 | 04:37 PM
Ferocity02's Avatar
I'm hoping the seller will refund my purchase or pay the bill for sending it back to Magnum for a repair.
Old Jul 24, 2012 | 04:43 PM
96s-10ss's Avatar
Is it a magnum or masterpower?
Yes the seller would be a stand up guy if he did that. But there arent alot of stand up guys anymore. Most spend the money they get from your purchase right away and dont have the extra cash to refund.
Old Jul 24, 2012 | 04:50 PM
96s-10ss's Avatar
Maybe it was dropped during shipping and got bent?
Old Jul 24, 2012 | 04:59 PM
Ferocity02's Avatar
I believe master power is now magnum.
The box looked okay, there are no signs of physical impact. Only sign of damage was one one of the compressor housing brackets was bent. The guy said he never used it, so he could have bought it bad. He is still at fault for selling me a bad part.
Compressor housing brackets:
Old Jul 24, 2012 | 05:04 PM
96s-10ss's Avatar
it may have been dropped bending a bracket and the backplate. Either way not your fault. Refund or paying for a repair is in order.
Old Jul 24, 2012 | 05:08 PM
96s-10ss's Avatar
You also may want to check the runout of the compressor wheel as it may be bent. 75,000 rpm and if its bent it will be terribly out of balance. Thats a recipe for disaster and possibly injury to the bystanders at the dyno or dragstrip.
Old Jul 24, 2012 | 09:03 PM
Ferocity02's Avatar
Talked to Magnum and they said they no longer carry parts for Master Power turbos. They said they usually scrap failed MP turbo's.
