Simple LS Swap Gone Awry (370/LS3 heads/PT88)
Old 08-04-2014, 05:19 PM
  #281
Slow94Formula's Avatar
Got another walbro 465 to put in the tank and turned up the fuel pressure to get a little bit more out of the injectors. When I was at the track last time it was running 92%-93% injector duty Cycle @ 17-17.5 psi. Now it's about the same at 23-24 lbs of boost. Most likely won't run that much on the street very often. Especially since I'm not even sure it's still making more power at that point, but I might have to try it out at the track.
Pic of the cobbled together pump setup... Guess which one is the new one
Ran RedRocketz28's old car Friday night (buddy of mine bought it)... He was running 16-17 psi. I was supposed to be too, but couldn't resist turning it up. I was at ~21 psi. We suck at roll racing so let's just call this a "speed comparison" instead.
We did a dig race too, but I forgot to hit record on the camera. Pretty much the same outcome though.
Old 08-05-2014, 07:06 AM
  #282
RedRocketZ28's Avatar
My poor old car getting worked over . At least it looked good doing so, lol.
Old 08-05-2014, 10:18 AM
  #283
I keep trying to talk him into getting it to the track. Pretty sure he will take it on October 4th if he doesn't wuss out by then.
Old 08-05-2014, 11:26 AM
  #284
I would have loved to see what it would have done on 16-17 lbs. and being able to leave in boost. When I had that MSD 2-step on it for a day it would build 6-7 lbs. with it set at 3200 rpm. That was more boost than it made on the footbrake last year with the 7875 turbo so I if it hooked I am sure it would be in the 1.4 60' range. I was able to get a 1.47 last year on the footbrake and about 4.5 lbs.
I will try to make it up there when you guys get it to the track.
Old 08-06-2014, 10:27 PM
  #285
I think it will run good if he can leave in boost. The gears feel like they last forever with the 3.00 gear though!
I'll make sure to let you know when he/we are going back down there.
Old 09-01-2014, 10:31 PM
  #286
Made room for some 325/50/15 nittos… I don’t like the wide look a whole lot, but as far as street traction goes they actually seem to work pretty good in comparison to the ET Pros I had on this spring. They tuck pretty nice everywhere except the rear bumper.
Heres the only picture I took of how the pros fit
Went ahead and bought a cage from MWC. Tore the car down the week after and it was in within a few days. While everything was out of the interior I went ahead and cleaned up the wiring… The best part was getting the aftermarket alarm box out of the car and back to stock. The car also had enough speaker wire in it to wire it another 3 times.
Anyways the cage turned out great and the swing outs are nice and tight. Since I know the welder will stalk this eventually... THANKS COREY!
The cage (mild steel) came to 98.5 lbs and with what I took out of the car it only gained 40 lbs. Which actually comes out to a wash for race weight since last time I was at the track there was a 40 lb salt bag in the trunk. I could have lost another 30 lbs if I took the rear seat out, but it looks more complete with it there.
Old 09-02-2014, 07:25 AM
  #287
wolfinsheepsclothing's Avatar
The new tires look great!
Old 09-02-2014, 07:24 PM
  #288
Thanks
Old 09-02-2014, 07:55 PM
  #289
a98ws6's Avatar
So you like the Nitto over the Pro's? Are they the same size? What did ypu paint the cage with? Looks very nice!
Old 09-02-2014, 07:58 PM
  #290
Traction, definitely not. Price for sure though! The Pros only come in 275/60/15 and the Nittos are 325/50/15.
Cage was painted with car paint. Just straight black... It's nice and shiny!
Old 09-02-2014, 09:27 PM
  #291
Camaro9969's Avatar
Awesome work man what did you paint the cage with???
Old 09-02-2014, 09:41 PM
  #292
LosLS2's Avatar
The contact patch on the 2 is very similar on a 10" wide rim. The Pro is not a 275, it's a "275" if you know what I mean.
Sure the much stiffer sidewalled Nitto feels way more stable on the street though, also the best DR in the rain. I run Mickey 325 DR on mine but she's a Sunny day only kind of girl. .
Old 09-02-2014, 09:51 PM
  #293
I do know what you mean. Had the pro next to a 295 et street radial and they looked nearly the same size. The Pro worked great on the street. Testing with the Nitto on the street with some traction compound went surprisingly well. I guess I'm going to have to take it to the track to see what these nittos are actually capable of. Not sure what to expect. Likely a slower 60' obviously, but I'm curious to find out how much worse.
Old 09-02-2014, 09:54 PM
  #294
LosLS2's Avatar
What was your 60 on the pros?
Old 09-02-2014, 09:55 PM
  #295
1.38. I'm fairly confident it had a low 1.3x in it on those tires as that was just as I was starting to bump the 2 step up and adjusting the shocks little by little. Will have another set before the year ends to try again.
Old 09-02-2014, 10:24 PM
  #296
LosLS2's Avatar
The Nittos should be able to cut some low 1.4 or even high 1.3's on a decentlt prep'd surface.
Old 09-02-2014, 10:32 PM
  #297
I am hoping for a mid 1.4 at least. Usually the track prep is pretty good where I go. I guess time will tell.
Old 09-02-2014, 10:38 PM
  #298
sweet99ss's Avatar
Just read through the thread from start to finish lol. Really amazing build and car just keeps getting cooler and faster. You do great work! Really funny you went from stock 240hp lt1 to 900hp turbo ls built everything lol.
Old 09-02-2014, 10:40 PM
  #299
Thanks hopefully it continues on that "cooler/faster" streak. lol
Old 09-02-2014, 10:45 PM
  #300
sweet99ss's Avatar
Awesome that you made such a detailed thread. Felt like I just read a good book lol. And from the looks of the work you do I'm sure it will continue to get cooler/faster! I wish I had the patience to do that kind of quality work! I just want mine to run good and get in the 10's for now!
Quick Reply: Simple LS Swap Gone Awry (370/LS3 heads/PT88)
