Explain this TT 375ci set-up...1100+ HP....how hot is this charge air...no IC.....
Twin turbos are within about 1 foot of the intake....no IC........![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
How hot is that charge air gonna be?????
http://bankspower.com/products/show/267/85
Its not making 1100 hp without the intercoolers.... Look at the proof tab where it shows dyno results.
Their 1100+ hp figures are on 100 oct fuel and intercooler since its taking 20 psi to do that.
91 oct non intercooled it only gets to 650-ish hp which is about right. Its only seeing 9 psi! 100 oct non intercooled can see 800 at about 14psi.
Assuming 75 deg air inlet temps, 50% humidity at atmospheric pressure, 9 psi is already at 174 deg F at 82.6% efficiency
Most turbos are no where near that high....something like 70-75 would be more realistic. 15psi at 80% eff is something like 233 deg F. its gettin hot quick
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
There was a buick guy who made more HP without an intercooler but was running 3 or 4 nozzles of alky to keep the temps down. I think he was running 20psi as well.
If its a custom designed wheel, for the boost range and motor requirements, I can see a high level of efficiency but I doubt its any higher than 80's % Even at that, you will have hot temps on higher boost levels. Alky is your friend if you dont have room for intercooler
SSU Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
that basic banks twin as been around for 15+ years...probably 20. Think 3rd Gens. Its a fantastic cast log that will never break...but because of the age, it was designed around a carb or TBI set up which would have an inherently cooler intake charge (fuel in the air charge vs. at the port). I have always wanted this kit with some 60mm in a 3rd gen with a CSU blow-through.
