my turbo set up
larger image
larger image mark
The ultima gtr is a kit car out of england. Custom tube frame, ls1 engine, porsche transaxle. US importer site is http://www.ultimacars.com/ UK Factory site is www.utlimasports.co.uk
Mine is a canam model so it doesn't have a roof, other than that it's the same as the gtr.
larger image mark
Are those blue tubes just mock-ups of how the headers will look or are they coverings? Can the Porsche transaxle take that torque?
Did you put the ultima together yourself or order it as a rolling chassis??
mark
Not really sure yet. We are in the process of trying to figure out where the high /low air pressure spots on the body are so know where to mount the intercooler and intake. The factory did extensive wind tunnel testing on the gtr but I am not sure it they tested the canam. Waiting to hear back from them. My hope is that the rear end of the car is high pressure and I an build a small scoop into the body to fill an air box to the right of the turbo. If not I will probably run an intake pipe up to the side intake vent. The intake scoop on the canam is useless because it is below the front windsheild
Larger image a stock Porsche transaxle can't handle very much torque so I had to have one custom built.
mark
It looked like it was going to cost around 60k to get the job done, and problems with licensing.
It looks as though you are pretty far along. How long did it take you to get this far?
Mike
If you leave the coil packs on the valve covers don't forget to leave room for them when you are mocking up the new turbo headers.
The kit arrived in the US in Jan 2003, I have a little under 400 hours of time in it already.
The car is street legal in the US. Each state has different rules for kit cars + different emissions standards. Most states base the emissions off the year of the engine. In those state you just drop in a pre 74 block and you have no emissions. States like MD base the emission off the frame, so if you title it in 2004 you have to pass all the 2004 emissions standards.
Since I live in MD and wanted to run an LS1 motor I was originally told by the DMV I would need to put in a 2004 block with all the emission control devices + onboard emissions diagnostic equipment. Luckily I got connected with a guy at the dmv who pointed out some kit car legal loop holes which in the end made the car emissions exempt. The car is basically registered has a street rod. No emissions, no inspection needed.
I am running a tecIII set up which uses its own coil packs, they are going to be mounted below the headers.
mark
larger image
larger image mark
