Crank Selection! HELP
Old Jan 15, 2013 | 08:24 PM
60fthnter's Avatar
Default Crank Selection! HELP
I need to order cranks and rods. I have done some searching in FI section and really cant find any threads on what guys are using. Here is the build sheet so far:
-LSXblock bored to 4.135 or maybe 4.155 (4in stroke or maybe smaller 3.8 or 3.9 input appreciated)
-Twin tc 76s (journal bearing)
Stainlessworks down and forward headers
-Cam is 24x/25x .632 .632 117 + x (originally spec'ed for my 416)
-FIC2000s (e85)
-4L80E with t-brak and circle d converter
-1000 plus rwhp is the goal (more would be better obviously, LSX block can handle way more so why not?!)
-TFS 245s 6bolt heads, nitrous exhaust port, ls3 valves, powder metal guids
I like wiseco pistons, or should i look at something different?
Right now I am thinking callies dragonslayer crank and callies ultra h-beam rods?
I want to hear ppls thoughts and suggestions.
Old Jan 15, 2013 | 09:16 PM
Stangkilr's Avatar
Oliver billet or callies ultra billet are good rods and dragon slayer crank.
Old Jan 15, 2013 | 09:22 PM
bad6as's Avatar
twin 76s are good for over 1500 I belive losls2 has twin 76s. But for 1300 I would think the dragonslayer crank would do it. The ultra billet callies rods I haven't herd much about.
Old Jan 15, 2013 | 09:38 PM
Realcanuk's Avatar
I think your making good choices. I'm having a short block built now by a top builder and its getting dragonslayer, caillies ultra H beams and wiesco pistons. All chosen after plenty of research and thought.
Old Jan 15, 2013 | 09:40 PM
68 SS's Avatar
Callie's ultra billet rods, CP pistons, and a Callie's magnmum crank here wanted to be sure I was covered no matter where I went with the combo.
Old Jan 15, 2013 | 10:13 PM
60fthnter's Avatar
What about storke length? I know the LSX block has a little longer sleeve, but I don't want to pull the piston too far out of the bottom.
Options I am considering:
4.00
3.900
3.825 ( magnum crank only )
3.625 (might not get me enough cubes for the cam, calculated a 399 with a 4.155bore)
Old Jan 15, 2013 | 11:06 PM
PROLSXSS's Avatar
Dragon slayer crank, callies ultra 'I' beams and diamond pistons that's the combo I'm running
Old Jan 16, 2013 | 12:09 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
4.00
3.900
Are you building the engine? If not I would talk to multiple engine builders and feel out who you are comfortable with. Talk prices, components, durability, your goals, etc... Asking random people on the internet is rarely a key to success.
Old Jan 16, 2013 | 12:33 AM
p8ntslinger676's Avatar
dyers 300m rod. there are people making over 2000hp with them. We are using manley 300m I beams with Carr bolts and make 1500 on quite a few of our GTR's with more room to grow (thats a V6 by the way) sonny bryant also makes great billet cranks. Just trying to throw some other options out there for you to check out.
Im personally using the Manley 4340 I beam on my 1200+whp build and they should hold up fine. And you might want to look at some different turbos, there is really no to ever buy a tc series turbo, you'll max out those exhaust sides before well before you'll ever even get close to maxing out the compressor side. get some journal bearing precision 67/66's or garrett GT37's with billet wheels.
Old Jan 16, 2013 | 05:27 AM
LS1NOVA's Avatar
When that day comes he can do a direct swap to a 7675.
Old Jan 16, 2013 | 09:24 AM
60fthnter's Avatar
I have working Brain Tooley on the combo and getting everything lined up.
The turbos came at a good price. I will run these and see how far they will get me and upgrade down the road. At this point I just want to have to together for summer.
Old Jan 16, 2013 | 01:42 PM
speedracer5532's Avatar
Dyer 300M rods and Callies Dragonslayer crank
Old Jan 16, 2013 | 02:02 PM
kickassT/A's Avatar
No need to blow the money on dyers rods. They are excellent pieces but not needed at that level. Oliver or callies billets would suffice
Old Jan 16, 2013 | 05:32 PM
LS6427's Avatar
4.00
3.900
3.825 does not ONLY come in Magnum. I have a regular Callie's forged 3.825" in my 390ci. $660.00 bought directly from Callie's.......
I'm going for 1,200 RWHO with twins......
Old Jan 17, 2013 | 01:52 PM
TheLS1Lover's Avatar
DragonSlayer Crank and the Ultra Billet I-Beam Rods. Anything else is not needed. Most of the Callies cranks are the same, just different options on each.
Old Jan 17, 2013 | 01:58 PM
hellbents10's Avatar
LS1Tech Sponsor
I like the Oliver rod when on a budget, we tested them to 2000hp for 50 passes with not one issue.
Old Jan 18, 2013 | 01:36 PM
60fthnter's Avatar
I order a set of Callies Ultra-H beam rods.
Now I need helping getting a crank ordered up. What are guys thoughts, I am thinking callies dragon slayer 4.00. The bore size will be 4.135 or 4.155.
Maybe get a smaller stroke but then I have to stray away from the callies dragon slayer.
Thoughts or opinions and other options are appreciated.....
Old Jan 18, 2013 | 01:55 PM
Get the Dragon Slayer 4.00".
