How many turbo guys are using these fans?
If so how do they work?
using 1 or 2 on your setup?
What radiator do you have?
street driven or not? How many miles? In traffic at all?
http://www.summitracing.com/parts/pro-67011/overview/
Here is what I run. I'm using a single 16" fan (3000cfm with stock radiator) and I have NO isssues at all. I sit in traffic and daily drive mine currently. I mount it on the front since its a pusher and have no issues.
http://www.summitracing.com/parts/hfm-zfb16s
Car in 70 degree weather while cruising is at 205 and stop and go traffic 208...longer lights 210. Cooling back down to 205 after sitting at a light. Personally, the car could be cooler. So I'm going to try something in conjunction with this setup.
1000cfm is pretty low.
Where possible, a large single is usually better. Or one big one small. The large single just covers more surface area of the radiator core compared to two smaller fans. Although obviously it depends on total area available etc and room for the fans.
