building a ls1 bottom end for boost, what to get
A stock LS2 block, stock crank, good forged rods/pistons and heads that flow well (TFS, AFR, AllPro etc) with an LS6 intake should have no problem making 1000rwhp with enuf inj and turbo/supercharger. Boost is addicting... you will want to turn it up after running it for a while. Trust me!
For a street driven high HP boost car it has also been mentioned a few times that an LS1 block over time (3-5K miles) can lose ring seal due to the bores getting out of round. Remedy is tear it down, light hone... new rings.... and then it is good for another 3-5K miles.... until it can happen again. This is more at the 800rwhp+ level. Do a search for it.
edit: Or is this coming from a high ratio of high revving/race miles?
