Purchased the new MS3PRO for my turbo 5.3!
Old 05-03-2013, 01:04 PM
T/ALT1's Avatar
Default Purchased the new MS3PRO for my turbo 5.3!
I ended up biting the bullet and bought the new MS3PRO from EFI source for my S475,5.3 bulid. I think for the features you can't beat the price $725 with the base wiring harness. Thanks to Denmah (Matt) It has boost control, traction control and many other features syuch as these:
•Supports speed density, alpha-N (TPS based), or MAF based fuel and spark tables
•1 microsecond injector pulse width resolution
•Tables for nonlinear injector behavior at small pulse widths
•Allows blending multiple load types, including specialized mode for independent throttle bodies
•Supports a wide variety of OEM cam and crank position sensors
•Individual cylinder trim tables for fuel and ignition
•Accelerator pump or model based acceleration enrichment
•Closed or open loop idle speed control
•Closed or open loop boost control with two separate wastegate outputs, and gear or speed based tuning options
•On/off or closed loop continuously variable valve timing (VVT) control - supports up to 4 channels
•On/off or progressive nitrous control
•Traction control by VSS or RPM
•Rally anti-lag with rotational idle
•Rotary support - can run up to 4 rotor engines with separate leading and trailing spark tables
•Staged injection
•Table switching
•16 x 16 fuel and spark tables - can be reconfigured to function as 30 x 16 or 16 x 30 by switching tables based on RPM or load
•2 or 3 step rev limiter (launch control) with no-lift shifting
•Wideband AFR target tables
•Flex fuel sensor input for easy switching between gasoline and E85 - can automatically change fuel, ignition, and boost maps based on ethanol content of gasoline
•Knock control with adjustable crank angle windowing can adjust sensitivity based on RPM or which cylinder is firing
•Allows repurposing injector or ignition outputs as general purpose outputs, or high current outputs as injector drivers for 12 cylinder sequential applications
•Real time barometric correction (external sensor required)
•A/C and cooling fan control with idle compensation
•Safety shutdown based on AFR or EGT input
•Sequential shift cut and air shifter control
•Diagnostics to detect and ignore failing sensors - can even automatically switch from speed density to alpha-N in the event of a MAP sensor failure
Old 05-03-2013, 01:35 PM
Reject's Avatar
very nice! when you say base wiring harness, what do you mean exactly by that?
Old 05-03-2013, 01:55 PM
T/ALT1's Avatar
It's not designed for LS engines, I will have to buy connectors for the injectors, map etc.. Then just put the connectors on and trim the wires to make it fit correctly, not a plug and play harness.
Old 05-03-2013, 02:15 PM
Moderator
denmah's Avatar
yep its just a giant pigtail 8ft harness with the 2 ecu plugs on it
he will be selling a plug and play harness with fuses relays, and everything,
Old 05-03-2013, 02:16 PM
Moderator
denmah's Avatar
i will be firing a 5.3 turbo nova with this box and starting to tune it as soon as all the parts come in!
hopefully just getting it started this weekend and making sure the motor is good!
Old 05-03-2013, 02:43 PM
T/ALT1's Avatar
Hey Matt would I be better off buying a stock LS1 harness to get connectors off or buy the individual connectors new? I could also go to a salvage yard but would rather just buy a used harness or the parts. Do you have any base tunes for the MS3pro or will the micro tunes work? Thanks Clint
Old 05-03-2013, 03:07 PM
Moderator
denmah's Avatar
its totally different, i have the tune for the ls2 that i did, with the stock injectors, i will be starting this 5.3 soon and i can give out the tune for that, single turbo 5.3 with a 68mm, truck intake and 80lb siemens injectors etc
i will post em up if you want
Mike @ efi source will be able to hand out the ls2 tune also
Old 05-03-2013, 03:59 PM
T/ALT1's Avatar
I would appreciate if you would give me the tune you put in the turbo 5.3, I just need something to get it started, I have 80# injectors too, something I can use as a base tune. Thanks
Old 05-03-2013, 04:09 PM
Moderator
denmah's Avatar
yeah i would like to fire it today before i send it to you, if thats ok.
otherwise ill send it to you tonight or tomorrow starting the car or not
i have something that should work, but i havent fired it yet
Old 05-03-2013, 04:23 PM
T/ALT1's Avatar
It's ok Matt take your time, I won't have MS3Pro until later next week and I'm still needing fuel pumps so it will be a couple weeks until I'm ready.
Old 05-03-2013, 11:02 PM
Moderator
denmah's Avatar
could not start it today, i think his crank position sensor is bad, engine is cranking steadily and i get 0-130-0--0-0-120 rpm haha i have never had that happen before.
so we are gunna replace the crank position sensor and try again sunday
Old 05-03-2013, 11:47 PM
88mmrocket's Avatar
Subscribing!
I talked to mike again today and I will be getting the prototype/first harness for the plug and play kit! Yay for me! Can't wait!
Old 05-04-2013, 12:39 AM
89ROC-Z's Avatar
newb question: None of that ms3 software is self tuning correct? I like the idea of having it self adjust to changes alleviating the need for me to run to the tuner every time i change something
Old 05-04-2013, 01:36 AM
95bowtie's Avatar
If im not mistaken denmah had a version like that I thought, it would self tune all the part throttle fuel trims for you....I could be completely wrong tho.
Old 05-04-2013, 03:16 AM
redss82's Avatar
tuner studio full version can self tune fuel but not ignition
Old 05-04-2013, 05:14 AM
T/ALT1's Avatar
Yes you can do self learning on this setup for target AFR and it will adjust accordingly.
Old 05-04-2013, 10:58 AM
vinnysnova's Avatar
This is cool, I just ordered my ms3 Thursday night! I will definitely be watching your progress. I have been looking for a startup tune also, but im on e85 with 95lbs injectors. I may have one from one of the diyautotune guys, if I see it I will share if anyone need it
Old 05-04-2013, 11:11 AM
tennerv8's Avatar
If you're using the full version of TunerStudio then yes it will self tune to a point. Its called VE analyze live. I am using this on my ms1 v2.2 flashed with the extra code.
Old 05-04-2013, 11:25 AM
T/ALT1's Avatar
Cool, I think the MS3pro comes with the Tuner studio but I'm sure Denmah can confirm this. The awesome thing is that I won't have to buy a boost control, 2-3 step, traction control or any other electronics! All this in one box, this has more features then the Holley setup!
Old 05-04-2013, 03:21 PM
88mmrocket's Avatar
This is the reason I am buying also! I'm pretty excited! If anyone has a base tune for 160lbers on E85 hook a brother up! Lol!
Quick Reply: Purchased the new MS3PRO for my turbo 5.3!
