PROJECT RED ROCKET TUNING HAS STARTED! AES390, Twin turbo, 4l80e. PG21, Post 408! :)
#65
Thanks man!
Thanks! I wasnt too sure on how the wrinkle coat would turn out. it was a $9 trial an error and i think they turned out pretty good. definitely a little different! The bay paint was a lot of fun to spray! It was really pretty simple to do. That was the first time ive sprayed anything with an hvlp gun.
Working on the engine harness now, i got it stripped of the old lume tonight, rerouted the alternator wire and start re-luming it with some power braid. Its gonna turn out pretty nice. I plan on having it done sunday, and the engine in next wednesday/thursday!
#68
If I were you I'd take my time with the engine harness. If I could do it again and not be in a rush I would have re-routed a lot of wires and extended a bunch. I'm pretty sure there is enough room under the battery to mount the whole PCM if you wanna get frisky lol. I was going to try but haven't got around to it yet and having the engine and everything installed already makes it more of a PITA.
#72
what happened? lol
thanks!
well I've relumed the engine harness with powerbraid and the only wire ill have to extend is the MAF. i havent got thesecondary harness mounted yet but have test fitted and it seems it'll all work fine wihout extending n e thing. plus u can't see it. if i need to extend anything i will. ill prolly tackle it here in the next week or so. next weekend, i plan on finishing up the downpipes and get the wastegates mounted.
say for not replying sooner, it didnt even update in my subscriptions...
thanks!
#79
Thank ya sirs! lol. Hopefully ill be able to start it by the end of august. We will see. Before i can start it, i have to..
-Finish DP and wastegates
-Fab cold side
-Buy/Install fuel system
-Relocate battery
-Buy/Install ABS Delete kit
That should allow me to start it and make sure nothing is going to leak, squeal, grind, pop, smoke or explode. Then itll be a waiting game on money so i can purchase a tranny and converter..
-Fab cold side
-Relocate battery
