turbo spark plugs
Old May 20, 2013 | 01:58 PM
5.slow99's Avatar
Default turbo spark plugs
i was wondering what everyone is using for spark plugs in turbo cars today
i have as follows
-stock 346
-76mm turbo .96ar
i know everyone has their opinions so let me know what you think, im sure theres plenty of you that have this setup so let me know what works.
thanks in advance
Old May 20, 2013 | 02:13 PM
hellbents10's Avatar
LS1Tech Sponsor
Br7EF for 550-750hp street cars here.
Old May 20, 2013 | 02:59 PM
denmah's Avatar
Moderator
yep i use a tr6 for up to 18lbs then a BR7EF over that
Old May 20, 2013 | 03:27 PM
a4ls2goat's Avatar
Br7ef here. 16-17psi. 723whp
Old May 20, 2013 | 03:44 PM
edwardzracing's Avatar
What gap size do you guys typically run?
Old May 20, 2013 | 05:18 PM
a4ls2goat's Avatar
I run them right outa the box.
Old May 20, 2013 | 06:49 PM
GMCtrk's Avatar
the BR7EF's I got were all right at .02 out of the box. I opened them up to .032"
Old May 20, 2013 | 07:38 PM
denmah's Avatar
Moderator
tr6 i bump down to 25 so i can turn it up to 20lbs if i want to without regapping the br7 strait out of the box its like 25-28 i just throw them in like A4LS2 says haha
Old May 20, 2013 | 07:56 PM
LS1NOVA's Avatar
I run BR7EF on E85 at 23lbs at .022 gap. Switching to B8EFS to turn it up.
B8EFS on E85 at 1000whp at .022 gap
Also had good results with cheap Autolite 103 on the milder stuff.
Old May 20, 2013 | 08:29 PM
denmah's Avatar
Moderator
yeah when we couldnt get tr6 or br7 and we wanted fresh plugs i have used 103s in a pinch problem free also
Old May 20, 2013 | 11:09 PM
Ryans99ls1's Avatar
Ran TR6s at ~11lbs and had great results. Switched to BR7EFs and upped the boost to 14lbs and it seems to like those as well. pure street car
Old May 21, 2013 | 12:25 AM
5.slow99's Avatar
thanks for the input guys, really helping me pick out a plug. forgot to say but i will probably be running 10-14lbs so everything you guys are saying is exactly what im looking for
Old May 21, 2013 | 12:54 PM
skinnies's Avatar
br7ef will be perfect for what you are doing
