Procharger Blow off valve question?
Old Jul 1, 2013 | 12:06 PM
stanggreg90's Avatar
Default Procharger Blow off valve question?
Is it worth it to get one? I keep hearing two different opinions, one is that there bad for the procharger or they help Thanks guys.
Old Jul 1, 2013 | 12:16 PM
stevieturbo's Avatar
It is worth it if you need, it. If you dont then no it isnt.
But you dont state your application to even guess as to whether you need it or not.
Old Jul 1, 2013 | 12:51 PM
dschmittie1's Avatar
Prochargers should have a bypass valve not a blow off valve
Old Jul 1, 2013 | 01:25 PM
I have the by pass valve on it but some people run it will a blow of valve, my setup is stock bottom end, 205 AFR heads 62cc, custom cam, d1 with 8lbs of boost, 6 speed car.
Old Jul 1, 2013 | 03:49 PM
As long as it vents air, it really doesnt matter what you call it.
Old Jul 1, 2013 | 11:51 PM
MR2liter's Avatar
Im running a tial q bov with the 2psi blower spring. It stays open untill boost comes on.
Old Jul 2, 2013 | 10:07 AM
Detoxx03's Avatar
Running a Tial Q on mine with a -6 spring.
Old Jul 3, 2013 | 08:38 PM
ss2000silverbullet's Avatar
From: Virginia - Where Rednecks and Presidents Come From
It depends on your belt drive capabilities and what kind of torque/hp curve you're looking for.
IF you have a belt/pulley setup that can run more boost without slipping, it's beneficial to add a BOV and get a smaller headunit pulley to make more "potential" boost.
For example, if your setup currently peaks at 8psi @ redline, then you don't get a big gain on boost 'til the top end of your revs. But, if change your set-up's potential boost to say 15psi @ redline (if there's no BOV installed), but DO install a BOV that opens at 8psi, you'll still be keeping your motor safe, but will achieve the 8lbs of boost sooner in your RPM range. Oh, and the sound is fu*#ing awesome, too!
Essentially, you'll have the bypass to prevent residual boost buildup, and the BOV as a max-level failsafe.
WARNING: IF the BOV ever fails and doesn't release at the correct pressure, you risk detonation and/or a blown engine! So, keep everything very clean, and always a sharp eye on your Boost and A/F Gauges!
Old Jul 3, 2013 | 09:22 PM
Wow that is some really bad info right there.
I think you are confusing how a wastegated Supercharged setups works and not a blow or valve or by pass valve works
Old Jul 3, 2013 | 09:34 PM
allout06's Avatar
Use what you want ... u can recirculate it with a bypass valve or just vent it to the atmosphere with a BOV... they perform the same basic function, to release pressure built up in the charge piping to prevent compressor surge.
Old Jul 3, 2013 | 10:10 PM
Detoxx03's Avatar
Ummm dude you are thinking of a wastegate not a blow off valve. They are two completely different things.
Old Jul 3, 2013 | 11:09 PM
My apologies....How 'bout a "Boost Limiting Valve". BLV, not BOV.
You're right, it's a substitute for a wastegate/boost controller....but looks like a glorified blowoff valve to me.
Here's a link so y'all don't think I'm completely stupid or insane!
http://www.928motorsports.com/parts/...mitervalve.php
Old Jul 4, 2013 | 03:09 AM
allout06's Avatar
ive got to say ive never seen that before.... i think id still trust a wastegate/boost controller on a supercharged setup though over that.
Old Jul 4, 2013 | 08:48 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'd keep it set up just the way you have it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 5, 2014 | 09:15 AM
cajundragger's Avatar
digging an old thread.
so if I have this correct- the BOV for a pro charger should be wide open at idle and manifold vaccum and close when manifold pressure get near atmospheric. correct?
so you run a light spring so that the BOV is 'sucked' open during idle and low load but the spring is strong enough to close as soon as manifold pressure approaches ambient.
and from above it looks like on a 50mm BOV a 2-6psi spring is adequate?
I'm installing a P1SC on a 5.7 and I'd like to run blowoff instead of a bypass. Just trying to figure out the ins and outs.
Thanks!
Old Nov 5, 2014 | 10:50 AM
conan's Avatar
Thanks!
The Procharger Bypass is wide open while the engine is in vacuum... Idle, part throttle ect. The Bypass closes when your vacuum system is at ambient pressure or possitive pressure.
Old Nov 5, 2014 | 11:16 AM
not the info I am looking for- albeit the bypass has to close sometime BEFORE positive gauge pressure is reached or it wouldn't close at all.
I understand how the bypass works.
I am curious about blowoff valves and setting them up.
Old Nov 5, 2014 | 11:53 PM
Blown06's Avatar
8 Second Truck Club
This thread should be deleted....lol
Old Nov 6, 2014 | 08:54 PM
yeah maybe I should have bumped a 'better' one.
Old Sep 27, 2016 | 10:56 PM
Corey Browning's Avatar
Default Hey
So what was the end result of this setup. Andvhas your bottem end been solid?
